Question about Black & Decker PI400AB Power Inverter
I got a P1400AB for Christmas. I used it once then using it on this trip..it worked fine at first then went to RED. I unplugged it...plugged it back in..it would go to yellow then red. Can you tell me what is wrong?
  • Anonymous Mar 04, 2011
    problem is it was a gift..not sure of where it was purchased
Hans Pearson
  • 2,510 Answers
Rather than try to repair it or look inot it, call the dealer or take it back to him as you will invalidate your warranty and that is not worth it. Let the dealer worry about it.
Posted on Mar 04, 2011
  • Hans Pearson
    Hans Pearson Mar 04, 2011
    What about approaching the person who gave it to you and explaining the situation, they could take it back for you?
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
TV red "on" light not coming on. Cannot get power to TV
The power supply board is dead.That the board where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suply board for the replacement.
Jun 10, 2010 | Element Electronics 26 in. LCD TV
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I bought a mini wireless optical mouse last year at christmas. The batteries went kaput so I put new ones in finally. For the life of me, I cannot find the instructions on how to sync it. I have tried...
unplug the usb reciever and plug it into another usb plug. then once it is reconized . press and hold the reviever button down for 5 sec. then press the button on the mouse that should make it resync
Oct 12, 2009 | Computers & Internet
I have to unplug the router power/turn back on, 4 laptop to work.
Try using 128 bit hex code. You put in a passphrase and it will scramble it into 13 pairs of letters and numbers. Use that instead of WEP. (192.168.2.1 in the address to get into settings for router, default password is blank)
Dec 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
Won't turn on
to behonest id take it back as if you mess with it you will lose your waraty
Jan 27, 2008 | Sony PlayStation 2 Slimline Console
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Black & Decker PI400AB Power Inverter Logo
337 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
