Question about Tissot Diver Seastar 660 Steel Large Bracelet Watch - Blue Dial T19.1.481.42
Do tissot make a automatic 100m sapphire date T354071105100 with a blue face Ken
Posted by glitterandda on
Robin Bonathan
  • 699 Answers
Yes but there are a lot of fakes out there.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 04, 2011
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
My tissot touch got crazy in the analog feature, how can I get it into normal?
The Tissot T Touch watches are very finicky. Many people have lots of problems with these watches. Just do a search and you'll find hundreds if not thousands of complaints about them.
What you are experiencing is not uncommon. Your watch will most likely need to be sent to Tissot for repair.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 07, 2010 | Watches
How do i adjust date and time
the knob at the side....
  • First pull which will change the date.
  • Second pull which will set the time.
thank you
Apr 06, 2009 | Orient Automatic Sapphire World Timer...
Meteo
1. How do you know the meteo is wrong? Are you comparing against a known good measurement device?
2. The altimeter requires adjustment every few days or whenever there's a weather change. Select the altimeter, hold the upper or lower button until you have the correct altimeter reading for where you are and it will hold for a few days.
For example, I know my home is at 100m elevation (I checked on a topo map) so I reset it to 100m when I leave the house in the morning. It varies (in my case) by over 100m in either direction, depending on the weather.
Nov 03, 2007 | Tissot T-Touch T33159851 Wrist Watch
Tissot Diver Seastar 660 Steel Large Bracelet Watch - Blue Dial T19.1.481.42 Logo
112 people viewed this question
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
