I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Cheers for the advice D3M0L1SH3R.
Have already tried it on 2 other Samsung TV's and it works fine on those (on various resolutions).
Yeap the component cables work fine on my TV, as you stated I have used these when reseting the resolution on the PS3.
I'll give Sony a ring next week to see what the score is.
Cheers
