What is the STR number used in power supply of tv model no kp-w41mh11 sony projection tv
  • 2,098 Answers
Hi adnan_khan_g,
KP-W41MH11 Voltage Regulator IC is the STR81159A.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Posted on Mar 04, 2011
Tv blinks 5 times...picture wont come on...sony model kp-51ws520
internal power supply problem. needs to be checked by service tech shop. also try a different power outlet to see if the set does the same thing? if it does then follow the above.
Aug 22, 2011 | Sony KP-51WS520 51" Rear Projection...
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
May 10, 2010 | Sony KP-65WS510 65" Rear Projection...
I have a KP-57WV7000 that will not turn on. I got
try to turn the tv on using the sony remote and this sequence of buttons push display 5 volume up then power if the tv comes on change ic8002 on the power supply if it doesnt try replacing anyway this is a common issue with sony tv's
Jan 24, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
The power safety fuse was blown. I replaced it but everytime I plug the TV, it blows the fuse. It is a Sony projection HDTV
When fuse blows again and again that means power supply is bad and needs to be replaced.
Let me know exact model of your Sony TV to provide you power supply board part number info.
Nov 03, 2009 | Sony KP-51WS510 51" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony KP-FX43M31
On the Sony FX43 100Hz 43-inch rear projection TV, three flashes indicates an Over Voltage Protection problem, occurring in one of the power supply circuits T603 or R672.
The fix will most likely cost more than the set is worth second-hand, I'm afraid.
Jun 28, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53V85
I need the model number to give you exact answer..i suspect power supply it is probably a sony tv common problem regulators go bad and cold solder joints or samsung.
thanks DOCTOR VIDEO
Apr 25, 2008 | Sony KP-53V85 53" Rear Projection...
Sony projection tv model kp-61v90
possible power supply or short on the b+ run,check for shorted horiz. o/p tranistor.
Aug 31, 2007 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
