Question about LG Audio Players & Recorders
Change regional code - LG Audio Players & Recorders
Posted by pkpool on
Chris Hingee
  • LG Master
  • 32,281 Answers
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVD from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From:-
www.dvdidle.com/dvd-region-free.htm
Posted on Mar 04, 2011
2answers
I own a 5-DVD Changer with a Home Theatre System. It is an LG Model # LH-E932TB. It was working great then all of a sudden it now says ''CHECK REGIONAL CODES''. Does anyone know what to do...
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
1helpful
2answers
My cousin bought a Phillips Portable DVD player for my kids. He bought it in America and in South Africa we have a different region code, can I change the region code
Question Can I change the region code on my player so that I can play DVD / Blu-ray disc from other regions? Answer South Africa is region B for Blu-Ray DVD and Region 5 for DVD and finding the procedure will be difficult as international copyright legislation prohibits manufacturers from providing instructions for changing the region code.
2answers
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD Player
Let me know if this Apple data helps!
Regards,
-Mactechtrainer
2answers
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
2answers
Region codes and windows vista??
Install Slysoft ANYDVD software, will bypass region locking on the fly.
It works very well.
1helpful
3answers
Changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
3answers
Changing the DVD Region code
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
3answers
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
2answers
Playstation 3
You have to get that specific region dvd player.
And no u cannot change the regional code.
Search for the regional code on the back of ur dvd cover.. should be though 1 through 6.
Top LG Audio Players & Recorders Experts
 Francisco Mauricio...
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
