Question about Cameras
May i known where is mudpot in banalore please i need a correct add ress with photo
Posted by shonashaik19 on
Raj Patel
    Genius:
  • 1,041 Answers
Did you mean Clay Pot Bangalore?
Near Market
New Thippasandra, Bengaluru, Karnataka 560075, India
080 51255109
Posted on Mar 04, 2011
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
Theft retail S1 theft act 1968 is there harm to visa wxtension
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 25, 2012 | Cars & Trucks
How to add photos to my radio,what do i need?
Sep 03, 2012 | 2008 Chrysler Sebring 2.7
How do I change date stamp on Model T328
If you're asking about changing the date on the camera, [ress the HOME button to bring up the main menu. Touch the pliers-and-screwdriver icon to bring up the setup menu. Touch the down-arrow until you see the "Date" option. Full instructions are in the "Date" section of the manual (page 42). If you need a manual, you can download one at
http://www.vivitar.com/files_products/9/ViviCam%20T328%20User%20Manual.pdf
If you're asking about the date stamp on photos you print, please refer to the documentation for whatever program you're using to print. If you can't find it, please feel free to reply to this post and specify the program.
Jul 10, 2011 | Vivitar ViviCam T328 Digital Camera
Downloaded photos for website wrong photo comes up
Your camera is creating new folders but not continuing the number sequence. You will need to manually rename your pics.
Sep 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Dishwasher bosch beeping noise
Found this on the Bosch website..... see 2nd to last step
The Cycle Completion Signal
This Cycle Completion Signal is a tone that sounds to alert you when your dishwasher
finishes washing and drying your dishes. You can either disable the tone or set the volume.
To activate:
· P ress and hold the right “Cancel Drain” button then press and hold the On/Off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone
begins to sound, release both buttons.
· P ress the right-most “Cancel Drain” button until the tone is either at the desired volume
or is silent.
· P ress the On/Off Button. The Cycle Completion Signal is now set.
Sep 27, 2008 | Bosch Dishwashers
NEED CODE
HAI, TRY ANY WILL ONE WORK.
1.PRESS TOGETHER SLEEP AND MENU SWITCH IN REMOTE,AFTER PRESS SLEEP SWITCH AGAIN.
2.PRESS MUTE SWITCH ONE TIMEAND RESS ONE TIME AGAIN.WHEN MUTE SWITCH IS KEPT PRESSED THEN AT THAT TIME PRESS MENU SWITCH IN TV FRONT .
Jul 05, 2008 | Televison & Video
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
