Question about Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point
I have no signal in my router - Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point
Posted by aleksheccid on
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
100 meter distance of router and cp has no signal
The rule I follow when using a signal booster, is read the manual of my gateway and check the Max range of coverage, if it is 50 meters I'll place my signal extender at 25 - 30 meters away from the Router, if you go to the edge of coverage circle, your signal extender will suffer unstable signal, and would fail to boost the signal.
Jul 28, 2011 | 3Com OfficeConnect Router
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
Xomputer will inexplicably lose the signal. A few
I think the problem must be with the router. When it drops the connection, you can see other networks but not yours.
that means at that time the wireless signal on your router must not be broadcasted.
WRT160N router has issues with the firmware. Youcan try to upgrade the firmware of the router.
firmware is the software of the router.
Once you upgrade the software, unplug the power to the router and plug it back in. wait for a moment and now observe the connection.
Click here for more information about the router and internet
Feb 26, 2010 | Linksys WRT160N Wireless Router
The signal light is blink and cant get a signal from the wireless computer. Do i need to reset my router?
First off, the computer gets the signal from the router, not the other way around. Secondly, depending on the amount of walls, thickness of walls, amount of interference, the range on your router may not be far enough to reach your computer. If you used to get a signal and no longer can, unplug everything and plug it back in after a minute, that usually fixes the problem. If there is still no signal, try moving your computer closer to the router, or the router closer to the computer. If it is simply that the router does not have enough range, consider upgrading to a wireless n router.
good luck, let me know if you need more help
Dec 29, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Low broadcast signal
Turn off or move any other gadgets that may emit a wireless signal. Other wireless signals may prevent the router signal from being as strong as it should be
Nov 27, 2009 | Belkin (F5D7633UK4A) Wireless Router
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
DI-524 wireless router no signal missing antenna
tat dlink device is a good device i shld techinically still produce signals
but wat happened to antena if it is broken u might as well go for new router
as far i remember u wont get antena seperatly
on ur mac book scan for signal see if u are pick up signal
if yes you are lucky it shld still transmit else go for a new router
Dec 08, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I keep losing signal
Try getting one of those signal checker's . You can buy them from circuit city for like $20 bucks or so. Then walk from your router to your computer checking the signal along the way.
Signals can be impacted by a variety of things... like walls, shut doors, etc.,. However, if you are standing in the same room as your router in clear line of sight and have no signal , you may have a bad router.
Jul 14, 2008 | NetGear DG834G Router
Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Logo
32 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
