SOURCE: Plasma went black. Power not interrupted.
I can confirm Vladislav/ Jaime867's repair... Had the same problem on mine. Replaced the same two capacitors and bingo back in action.
I think the issue is that the capactitors sit between two heat sinks and if the display is flush mounted to the wall there is poor ventilation in there. I'm going to get a better mount and hopefully this doesn't happen again.
Cheers and thanks for the great fix!!! Only $4 bucks!
-Jon
SOURCE: remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
SOURCE: my new samsung ps42a457 plasma tv wont keep its modified settings
hi hold down exit botton until menu appears,it is set in shop demo please select home use and follow instructions that will sort it
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
