Belkin F5D8236-4 Router Logo
Aline Schiesz Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I set up wireless network for my boss, using Belkin wireless n router, so the 3 computers can connect to the same wireless printer, and she can access this network with her home laptop. All is well except that she can't access any secure web sites through the network, although she can when she works from home. I've searched through so many tech advice pages, my head hurts, and have done everything suggested, but still am unable to access secure sites from any computer in this network. It has to be something in the router, correct? Since her laptop can reach secure sites at home but not at work. Please help, as I'm feeling I made some stupid mistake that is causing my boss to have to take work home to process client billing instead of being able to do her billing at work. The website that she needs to access is https://terminal.securenet.com/
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1614
Points
29
If possible, to rule out the modem as the cause, connect a computer directly to the internet(bypassing the router entirely). If it is the router, you could try flashing it back to factory defaults and reconfigure. Log into the router's firewall feature and see if port 443 is blocked to the outside--this could cause https connections to fail.
Tony
Level 3:
Master:
  • Master 451 Answers
Tony
Master
Level 3:
Master:
Answers
451
Questions
0
Helped
121233
Points
1215
Are you using a proxy server or any other firewall?
try and reset the wireless router and reconfigure it.
How do I connect my Macbook to my Kodak wireless printer with my Belkin G+MIMO router?
When you added the WPS encryption ket to your wireless router, this secures your wireless network from unauthorized access to you wireless network.
To allow your wireless computers and wireless printer to communicate with your wireless network the wireless cards in the computers and printer needs to be configured with the WPA encryption settings that you configured in the wireless router.
I am using Windows 7 Professional and have a network computer connected to one of the computers. I am trying to install a Belkin 8236-4 wireless modem. It works fine, but it causes the network printer to...
very simple. change the ip of printer to same belkin router network.
like make it 192.168.2.55. becuase both on different so it will not print.
in case you have wired and wireless network both connect same time. it should print without any change.
3helpful
3answers
How to connect my laptop wirelessly to the belkin router?
You may want to click to wireless network icon on the bottom part on the rght part of your monitor and search for network. Then you may want to chose your network and, if you chosed this option, to type the password for the network.
Let me know if you were successful in solving your problem
1helpful
How do I connect my wireless laptop to my Belkin wireless G version 8000 Router?
First you will need to check the wireless settings of the router. Is there any computer connected to the router or any computer online using the router ? If not then you will need to connect a computer to the router with the cable. open the set up page of the router. check the wireless settings of the router.
Once you get all the settings of the network, you will need to connect to the wireless network.
Connecting to the network will depend on your computer operating system.
Click here for more information about the router and networks
I am using a Belkin router and I cannot connect to Internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
2answers
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
3helpful
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Belkin Universal Wireless Extender Set-Up Problems
Have you tried restarting and resetting the router as well ?
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
