Hitachi PJTX100 Multimedia Projector Logo
A
Anonymous Posted on Mar 04, 2011
The image is mirrored on both sides one i red and one regular. I have replaced the lamp.
Anonymous
Level 2:
  • Expert 442 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
Answers
442
Questions
Helped
176956
Points
703
When you use menu, setup, mirror does it change on the screen, or is the red always on one side
Sanyo PLC-XU305 Projector
Being an old projector and possibly it has an old lamp fitted.
The lamp as it ages produces more heat. The fans as they age unless cleaned regularly. This build up of heat damages firstly the blue LCD imager and then the red.
Nothing can be done about that except replace the LCD imagers.
As a Sanyo Authorised service department, we used to charge them out at £1031 plus fitting.
2answers
1996 grand cherakee.Fuse Panel diagram
Good lord there are fuses everywhere in that truck if I remember right, you'd have been better off asking about the problem I think.. try here
http://www.jeep4x4center.com/knowledge-base/index.htm#service
find your truck, pull up the PDF then on your keyboard hit the find box (F3?) punch in "fuse" and run down the list...
For the basic panel
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): CAVITY FUSE DESCRIPTION 1 10 amp (RED) Radio 2 15 amp (Lt Blue) Cigarette Lighter 3 10 amp (RED) Rear Washer Switch, Body Controller 4 10 amp (RED) Airbag 5 10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 20 amp (Yellow) Body Amp, Cluster, Body Controller 8 20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 15 amp (Lt Blue) Brake Switch 10 10 amp (RED) Rear Window Defroster 11 10 amp (RED) ABS Module 12 10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 15 amp (Lt Blue) Spare 15 15 amp (Lt Blue) Spare 16 10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 20 amp (Yellow) Spare 19 15 amp (Lt Blue) Passing Light 20 15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 15 amp (Lt Blue) Power Outlet 22 10 amp (Blue) Airbag Module Turn signals are in the flasher and it is located on the driver side below the dash (where the buzzer is located). It is a cylinder type relay. You will find two, one for the hazzard lights and the other for the signals.
A red shadow along side images
It sounds like the lamp or light guide didn't get back in the exact original position...
Removing bathroom mirror
I RECOMMEND USING COMMAND INSTEAD OF GLUE.TRY TO MOVE TO THE MIRROR FROM SIDE TO SIDE WHEN LOSE ENOUGH PULL OFF.
- ANNA LEIGH MASON
Need to know lamp number. picture is dark and want to replace it.
Hi, Your TV does not use lamp. It has three tubes, red, green and blue. Probably one of the tubes are defective. Yoke can also be a defective. Perhaps the mirror can be very dirty. There are several solutions, depending on how you see the image. take back cover off the TV and see if it's dirty mirror and projectors, can be cleaned, otherwise, you need technical assistance from a TV shop to have no future problems. Any further questions , I will be here.
4helpful
2answers
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
7helpful
On my 2008 ford F350 the driver side mirror marker lights are not working. I need to know how to repair them. Thanks
If it's just that the bulbs that have burnt out you'll need to position the exterior mirror glass inward toward the vehicle.(Note: Use caution to not trap the side lamp assembly wiring during installation, or damage to the wiring may occur.) Using a flat blade screwdriver or something similar, push the mirror side lamp assembly forward while releasing the retaining clip. Separate the bulb holders from the mirror side lamp assembly and remove the side lamp. Replace the bulbs and reassemble. I hope this helps you out.
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Shadow
I am having the same problem and am looking for a solution.  I do know what is causing it however.  Between the lamp and the lens system there is a small square tube made of mirrors that are glued together. One side of the mirror has come loose and is in the line of the light being projected by the lamp.  I have attempted to fix this by reglueing the mirrors, but it doesn't take long to fail again.  I am trying to find a replacement or an upgrade, maybe polished stainless.  The part is small, made of some type of plastic and cheaply made.  I am disappointed that such a seemingly insignificant part could be the root of such a problem.  Not impressed.
1helpful
4answers
1/2 the screen is viewable
You would be wrong. Lamps do not do that. They either work or they don't, they do not cast shadows or give half an image.
What is going on is the light tunnel has failed. It is a small, 4-sided mirrored tunnel that focuses the light into the optical chamber. It is directly behind the color wheel. I've seen this probelm dozens of times.
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
