Question about Activision Call of Duty Black Ops
My black ops screen turns black on the level the defector, when i help woods push the door?
Posted by saleenpollo1 on
1 Related Answer
Anonymous
SOURCE: Black Screen in Defector mission of COD7 (Black
I just had this problem. The screen was blank, except for the direction and compass in the right hand corner, but the sound is still there. Seems to be a bug. I simply shot up a few people, went to the door, waited about 4 seconds without pushing the door, then just before the car came towards us, hit the square but to help push. Then it seemed ok. If you push from the start you may find the screen goes blank.
Posted on Jan 29, 2011
How Would I know if my tablet was broken?
hi not op.. but searching for help. Battery @ 100% and touch screen buttons not recognizing touch... This tablet belongs to my disabled 7 yr. old HELP
Feb 26, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Fog light replacement
The defector shield is held by pushpins, pull the center of the pin out and the whole pin will come out. You will have to raise the car or climb under and remove the pins only on the side you are working on, twist the bulb out, remove and replace. Push defector shield back and put the pins back in
Apr 22, 2013 | 2004 Pontiac Bonneville
When i play certain zombie maps on black ops it doesnt register the levels wen i eventually die can you tell me how to fix this problem please?
if you are not online than the scores dont register you have to be online in in a privote match with someone eles
hope this helps :)
Jul 04, 2012 | Activision Call of Duty: Black Ops
I have the Woods 59018 In-Wall 7-Day Digital Timer, and am having trouble installing it. I am replacing an IntermaticModel EJ251 timer that only connects using two black wires in the junction box (as...
Open following link to identify timer, read wiring instructions, and download on-line manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
How to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
Black Screen in Defector mission of COD7 (Black Ops)? In Call of Duty black ops, in Defector mission, after pushing the door, car explodes and screen goes to black but sound remain properly. I have the ps3...
Dec 28, 2010 | Activision Call of Duty Black Ops
Black ops ps3 when i'm playing the defector mission when you have to help woods open the door there a explosion and your knock out for a split second and when you wake up the screen goes black and there is...
black ops ps3 when i'm playing the defector mission when you have to help woods open the door there a explosion and your knock out for a split second and when you wake up the screen goes black and there is sound and all you see is the pointer what up i got a new game and the same thing also happen to the new game is there a glicth in the game and what do i do to fix it!!!
Nov 25, 2010 | Activision Call of Duty Black Ops
Playing Xbox Call of Duty Black Ops. On the defector level and screen goes black halfway through. Can see direction arrows and hear whats going on but nothing else. Is there a fix?
you have a faulty disk. i would take it back to the store you bought it from and exchange it for a new one. remember to bring you're receipt
Nov 16, 2010 | Activision Call of Duty: Black Ops
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Activision Call of Duty Black Ops Logo
285 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
