Your magnetic head on your floppy disk is dirty.
you can clean it with floppy disk cleaner or open your floppy disk drive and cleaned it manually.
i suggest soft material like cotton and alcohol or other electrical cleaning liquid.
and hope help you.
Hi, here it is the best solution. FlexiDrive floppy drive update.
It is working fine with any equipment.
No more floppies! No more Floppy Drive Units!
http://www.floppyemulator.com/products/flexidrivemv-usb/
[email protected]
Cheers!
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You
can store your BIOS into a floppy disk or a hard disk with FAT format.
Then, you will be able to use AFUDOS to access the BIOS ROM file.
If
it is not convenient for you to use DOS and AFUDOS, you can try to use
EZ Flash. You can save the BIOS file into a flash disk then boot the
system and enter BIOS, then you can update your BIOS by EZ Flash which
is in the BIOS Tools page. Please load the default settings in BIOS
after you have succeeded updating BIOS.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
