Question about Gaggia Titanium Espresso Machine
We are getting a "ventilate"
Posted by jean41 on
Ginko
  • Gaggia Master
  • 19,396 Answers
Hi.
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Regards.
Ginko
Posted on Mar 28, 2011
Ventilation Problem
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 25, 2010 | Saeco Royal Professional Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
On the screen is the error message - ventilate- wjat do I do?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
May 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
How do I ventilate my gaggia coffee machine
May 15, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony "ventilate"
May 04, 2010 | Gaggia Syncrony Espresso Machine
What does ventilate mean?
"Ventilate" simply means that there is an air pocket caught in the system and running water through it can fix the problem. When the ventilate message appears, you will need to run hot water through your steam/hot water wand as if you were going to fill your cup with hot water. If the message does not go away after doing so, you will have to run hot water through your wand continuously into an empty container (emptying one full water reservoir if not more). Once your display screen reads "Select Product, ready for use," you will be ready to brew delicious coffee again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Gaggia Syncrony Compact Digital Espresso...
My Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Nov 10, 2009 | Gaggia Titanium Espresso Machine
The message ventilate is showing and the machine won't work at all. It started when we used the steam to froth milk.
As pointed out by bansheracer, "Ventilate" means you need to open the valve on the right to let out some steam from the milk steamer wand. This can also happen if you accidentally push the 'steam' button but don't actually let out any steam.
If it is stuck or needs cleaning, unscrew the metal piece and dip the plastic bit in a jug of hot water - it should resolve most of the dried milk in about 5-10 minutes.
Oct 22, 2009 | Gaggia Titanium Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
723 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
