Question about HEWLETT-PACKARD Office Equipment & Supplies
You have to go into the settings on the fax machine. There will be an option for a prefix number. Someone put a 9 in there. Having the 9 in there will make it dial a 9 then the number you are trying to faxt too. Remove the 9.
Posted on Mar 03, 2011
So your fax machine defaults are set to dial a "9" before the number and you want to change this setting - am I correct?
If you are using the fax machine without connecting it to a pc, then you can change the default settings by using the keys on the printer. Go to "menu" and press it, then use the up and down arrows to navagate the choices until you see "fax set up" and then push "ok" or "enter". Then continue scrolling with the arrow keys until you see "my location" or "set up dialing".
If you are using the fax machine through the pc and its connected tot he pc, then the default dialing options are probably set in the computer. If this is the case, go to your control panel, look for phone & modem and click on it. Then browse the set up choices until you find the area code and dialing prefix entered for your location and correct it to what it should be.
Sep 05, 2011 | HP LaserJet 3390 All-in-One Multifunction...
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
Mar 17, 2011 | HP LaserJet 3390 Printer
Mar 02, 2011 | HP LaserJet 3390 All-In-One Printer
Click the Windows ( ) icon.
Click All Programs .
Click Windows Fax and Scan .
Click New Scan , and then click Scan .
Feb 26, 2011 | HP LaserJet M2727 MFP Series PS
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
Apr 16, 2010 | HP LaserJet 3050 All-In-One Printer
Aug 25, 2009 | Office Equipment & Supplies
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Mar 25, 2017 | HEWLETT-PACKARD Officejet 4500 All-in-One...
213 people viewed this question
