Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Please give us step by step instruction on how to change ink cartridge?
Posted by nmatthews110 on
Fazal Enterprise Ltd
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 82 Answers
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • Posted on Mar 03, 2011
    How do I change Ink Cartridges in Epson XP- 100 Printer
    This video isn't the XP-100, but the instructions should be very similar.
    Feb 22, 2015 | Epson Office Equipment & Supplies
    I need a manual with the instructions how to replace ink cartridges
    Depend of the brand name and model number of you printer..also try to check-up your printer Casing.
    I know some printer have instruction already wrote at the case of your printer "how to change printer Ink cartridge. also you can replace your ink cartridge using software operating system command.
    Try to do this step.
    Click start
    Click printers and faxes > right click your default printer icon ( like hp, canon etc.) > choose and click properties
    Click printing preferences
    Under printing preferences you can see there services
    Click services
    And then choose cartridge replace( please follow software step-by-step instructions to replace your ink cartridge just read the instruction carefully)
    Hope this information will be helpful.
    Regards
    Aug 25, 2011 | Office Equipment & Supplies
    How to refill ink cartridge of Epson me32?
    Follow these steps:
    1.
    Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
    2.
    Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
    3.
    Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
    4.
    Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
    5.
    Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
    In case of any additional help please revert back
    Jun 12, 2011 | Office Equipment & Supplies
    Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    How do i change ink cartridge
    While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
    Purchase an ink cartridge made specifically for your printer.
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    How to install the ink
    Step 1 Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low. Step 2 Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step 3 Press the change cartridge button. It is at the top of the printer next to the power button. Step 4 Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step 5 Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step 6 Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step 7 Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
    Want to know more then please go through this HP Website link - Click Here
    Anand Kumar Fixya
    Apr 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
    How do i change my ink cartridge pls
    here's a link where it will give you instructions on how to change your ink carts on your printer. http://bit.ly/dcwKyN . Your printer may not look like the printer illustrated on the page but it's a general instruction and the steps are the same. Hope this will help you.
    Mar 08, 2010 | Lexmark X4550 Multifunction Wireless Color...
    How do you change the toner on the MP450
    I am assuming you mean the ink cartridges.
    Go to this page: MP450 Support
    If the Support & Service tab is not selected, click on it. In the Search box type replace ink and click Search. One of the results will be "How do I replace the ink cartridge(s)?" Click on it.
    This will give you step by step instructions with pictures to help you replace the cartridges.
    Thanks for using Fixya.
    Nov 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
    Please can you tell me how to change the ink cartridge in the hpdeskjet 45c printer thank you
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3645100&lc=en&cc=us&dlc=en&lang=en&cc=us#
    If you got to the above link it will allow you to download the manuals for this printer, which will give you step by step visual instructions on how to replace the ink cartridges.
    If you need further assistance with this, let me know I CAN solve this problem!
    Thanks,
    Jim
    Aug 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
    How to change ink cartridge on a HP Officejet R40
    Hai
    Please click on this link, and you will find the instructions with Pictures to change the Cartridges
    Change the INK Cartridges
    Thanks
    Riz
    May 30, 2008 | HP OfficeJet r40 InkJet Printer
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    234 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
