Question about MPMan MP-F75 MP3 Player
I have an MP-cs187 how do I charge it? - MPMan MP-F75 MP3 Player
Posted by aosborne985 on
Anonymous
I beleive this model of MP3 player are not rechargeable as you require the use of an external battery for it. It takes a AA battery.
You may use AA rechargeable battery but you will require a charger for these.
Posted on Mar 03, 2011
THIS IS THE QUESTION I ASKED:WHERE CAN I GET THE MANUAL FOR THE KMASHI K-MP 812? THE RESPONSE I RECEIVED WAS ABOUT PRINTERS. THIS IS NOT A PRINER OR COPIER. IT'S A PORTABLE USB DEVICE CHARGER - LIKE F
This is all you need to know:
1. The larger of the two slots on the portable battery is a regular USB slot. You connect the USB charging cable of the device you want to charge (cellphone, tablet, iPhone, iPad, iPod) to it so the device can be charged on the go.
2. The smaller slot is a micro USB port that is used for charging the portable charger itself using the micro USB cable that came with the KMASHI K-MP 812. You charge it by connecting to a regular USB slot on your PC and then take it with you on the road to charge your device.
KMASHI MP 815 2200mAh Lipstick 5V 1Amp Rod Pocket External Extended Backup...
Jan 16, 2015 | Audio Players & Recorders
RICOH MP 2000 ERROR OCCURED SC302
That is a charge roller current leak. A current leak signal for
the charge roller is detected. Possible cause- charge roller damaged or high voltage supply board defective. Check the charge roller first. On the drum, the rubbery roller.
Jul 10, 2014 | Ricoh Aficio MP 1600L Black and White...
My coby mp-c582 just quit playing. does it need charged?
yes, connect it and let it charge for several hours.
Feb 15, 2011 | Coby MP-C582 MP3 Player
My mp-c7085
THE INTERNAL BATTERY NEEDS TO BE REPLACED OR THERE IS A BROKEN WIRE
Feb 01, 2009 | Coby MP-C7085 MP3 Player
How to charge my sansa mp 3 player
it doesnt matter if the mp3 is on or off if its off the mp3 turns on when you connect it to the computer or the wall charger then starts to charge if its on it just starts to charge
you should be able to see the little battery charging
Nov 12, 2008 | SanDisk Sansa E280 MP3 Player
Coby mp-c 7095
make sure its charge for at least 3-4 hours, if that doesnt work, or it doesnt hold a charge, battery is bad, which means defective unit.
Aug 19, 2008 | Coby MP-C7085 MP3 Player
Coby mp-c7095 mp3 player will not charge was working but not now
Just got Coby MP C7095 MP3 Player 2 GB for Christmas and the power would not turn on. I tried to charge it but still nothing happened.
Nov 13, 2007 | Coby MP-C7097 MP3 Player
MPMan MP-F75 MP3 Player Logo
Top MPMan Audio Players & Recorders Experts
Are you a MPMan Audio Player and Recorder Expert? Answer questions, earn points and help others
