Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
Brother first thing If you are not able to connect to your wireless connection then you can not enter into your Wireless Access Point router page.
To enter into your EnGenius ECB-8610S 802.11a/b/g Wireless Access Point page to make changes in your wireless settings you have to connect the Ethernet Cable or RJ-45 cable between your Access Point router to Your computer.
then check the Default gateway of your Wireless Access Point router to make sure it connected through ethernet cable properly:-
start>all progremmes>accessories>command prompt>Left click on command prompt> it display a black box> there is a cursor blinking by default>just type there now IPCONFIG and hit Enter.
Ethernet Adapter local are connection IP V4 address x.x.xx.
Defoult Gateway x.x.x.x
defoult gateway could be 192.168.1.1 or 10.0.0.1 so whatever it is then you can go to web browser then Enter your Defoult Gateway and you will be able to get into your Access point router page and make changes in your wireless settings after that once you connected to your wireless then took out the Ethernet cable.
after that even if you are not able to setup wireless connection let me know
This device can be configured as a Bridge/Router or Access Point. The default IP
address of the device is 192.168.1.1 (Client Bridge mode), 192.168.1.2 (Access
Point mode). In order to log into this device, you must first configure the TCP/IP
settings of your PC/Notebook.
Full instruction is spelled out on the manual:
http://www.google.com/url?sa=t&source=web&cd=4&sqi=2&ved=0CCsQFjAD&url=http%3A%2F%2Fwww.senao.com%2Fimages%2Fwww.senao.com_English%2FNCB-8610-UsersManual-V2-1_20070618.pdf%3FCATNO0%3DB%26CNT%3D0&rct=j&q=senao%208610S&ei=ZMJvTe7dApG2sAPtrO3DCw&usg=AFQjCNGsZfaDMP2VpGhwGasqnJxwiBvlgg&cad=rja
Hope this link will help you.
