Question about Pioneer DEH-P6800MP CD Player
I have a pioneer dehp6800mp and i want to install a ipod adapter cable, will the pioneer cd i 200 work? and will it also charge my ipod while its plugged in?
Posted by dariuswendel on
Tony_DIY
    New Friend:
  • 33 Answers
You would need the Pioneer CDIB100 iPod adapter instead.
It might charge your iPod, but it does not charge some iPod devices such as the Nano, iPod Touch, and iPhone.
Posted on Mar 04, 2011
Hi, i have the ipod ipbus cable withouth the pioneer cd-ib100 unit. will i be able to play my ipod. this cable has a red and black cable PWR N EARTH which i have connected, this is for charging and does...
Do you have the actual CD-IB100 box from pioneer, or is it just cables and wires?
Make sure you have the IP bus cable plugged into the right port on the CD-IB100
Feb 06, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Where do i find the port to plug in my usb for my ipod?
behind the unit where the connection wires are, is a black cable that has a usb plug in the end of it. although to play ipods in the unit, pioneer recommend using the CD-iU50 adapter cable. a normal ipod cable may work with certain ipods so i would try that first. I am pretty certain that it just wont charge certain ones. if you bought the unit new it should have had a usb extender cable included in the box.
to access the cable you will need to remove the source unit to plug in your ipod cable.
i hope i have helped you and please dont forget to rate.
cheers
Jan 14, 2011 | Pioneer DEH-P6900UB CD Player
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
Just purchased a 32 gig ipod touch . the unit
It appears as though you are attempting to charge the ipod with a cable that is not compatible. Some newer ipods cannot be used with older chargers and adapters for cars. Apple does this to maximize their profitability and in my opinion rip off consumers.
My daughters new ipod will work on her old FM adapter in my car but it says it does not support it on the ipod itself. It will transmit through the wire, but will not simultaneously charge it as the older ipod did both.
It is similar to cell phones and batteries. If you own the original razor and upgrade to the next generation razor, the usb connectors are different (hence the chargers will not work) and the battery connections are different so you cannot interchange batteries between the two. Even though you would think Ipods are Ipods and everything should be interchangeable, they are unfortunately not.
I hope this helps and good luck!
Feb 01, 2010 | Pioneer DEH-P6900UB CD Player
Pioneer dehp6800mp
due to having a ribbon cable inside the faceplate behind the screen the solders always break in them. it is fixable. but you need to unscrew it open and resolder it.
Aug 18, 2009 | Pioneer DEH-P6800MP CD Player
My ipod adapter for my stereo isnt charging my ipod
depends on what ipod you have.. this until will not charge- 2 gen touch, 4 gen nano, or iphone. if you don't have one of those, check your wiring.
yellow - 12 volt constant
black - ground
ipbus cable plugged into blue square ipbus on back of radio, and plugged into black ipbus on ipod adapter
Aug 13, 2009 | Car Audio & Video
Pioneer DEH-P9300 and Ipod Adapter Problem
The correct iPod adapter for this is the CD-IB100ii, not the PAC piece you bought. With the correct adapter you will be able to charge your iPod, get text and control from the head unit, and of course audio playback through your system.
Apr 23, 2009 | Pioneer DEH-P9300 CD Player
No video from ipod
Do you have the green cord that attaches to the parking break hooked up?
This stereo is designed so that you cannot watch videos while driving, therefore you need to have the parking break on in order to get video.
when you play a dvd with out the parking break on, you will only get sound.
Mar 18, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod connection
As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
Dec 29, 2007 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P6800MP CD Player Logo
200 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
