It seems that your phones firmware has corrupted.you musttake it to the service store or if you are good enough with computers,followthese instructionsFirst
download and
install Pheonix.
NokiaPhoenix Service Software 2011 -Download secondly
Download flash file from this link
Nokiaflash fileandinstall it to
C / programme files/pheonix..afterfinishing this installation open pheonix Inside theinterface at the> left top File" click there and choose "
openfile" and then select the appropriate
Product type i.e"whichis written in the back banel inside the battery of every Nokia(
Type RM-000).Afterdoing this again at the left top count from "File"1..2..3..the 4thone is "
Flashing" press there when you click there you'll seethreeicon just select the "
Firmware Update" again you'll seeanother interface .Look at the product code there should be blank and put your "mousetool" at the straight end from the "
Product Code" thereis a
Botton and choose the code which is written in the back sideof your phone. e.g
CODE:0000000.if the same code does not found, justtake one.After this you can see "
Dead phone USB flashing" clickthat box .Now this is the last stage... Connect your phone with the
USBtoyour
PC and let the driver install ...wait for a moment.(
If yourphone working).Lastly after just finished
(In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "
Referbish"afterthis, a message will prompt you "
press power botton"press it and wait untill the phone will Restart automatically
