Question about Sony SLV-D380P DVD Player/VCR
Which components is responsible for the auto tracking in the sony vcr, model slv d380p
Posted by stephenssr_w on
Demonic-2011
  • Sony Master
  • 512 Answers
Auto tracking, or 'digital tracking' as it is sometimes known, is generally governed by the CTL (the linear control track head), located toward the right-hand side of the main head cylinder drum, along with a combination of the guide posts/rollers, the capstan speed as the tape travels in the deck, and of course the drum balance since this rotates the fastest. Usually this is pre-aligned to factory standard, but as parts wear down, the alignment changes - hence your 'tracking query'.
Presuming you have a video picture from your tapes on the TV screen, you can bet the tracking is controlled electro-mechanically (as above). One of the first parts on the mech to wear out is the rubber pinch roller - when it becomes glazed or shiny, tapes can be chewed and/or the 'control track' drifts during playback - more so than when recording.
Nevertheless, it is usually a simple workshop repair involving inexpensive part replacement/alignment on the mechanism including a new pinch roller and cleaning of the entire tape path. The only 'cost' would be labour on top of the parts. The option here is that you can submit your unit to a workshop/service centre for a quote on repair/parts costs first, then decide if you want the tracking fixed - up to you. I hope you have no other really serious issue with this combo unit - SONY is a premium brand - trusted and reliable. I assume the DVD section works fine.
Remember; bad tracking is not always a mechnical mis-alignment - it can also be the quality/age/condition of the tapes a person uses as well, even if that person doesn't 'thrash' tapes on a daily basis. From memory, the SLV-D380P is one of SONY's better DVD/VCR combos.
Posted on Mar 04, 2011
Can Sony D380P play blue ray disc.?
If your player is the Sony SLV-D380P, the unit does not play Blu-ray discs. It is only a DVD player and VCR. It can play some CDs. The discs must be finalized for homemade video DVDs and audio CDs. You can find the specifications and manuals here: https://esupport.sony.com/US/p/model-home.pl?mdl=SLVD380P&template_id=1®ion_id=1&tab=manuals#/manualsTab .
I hope this helps.
Mar 17, 2016 | Sony SLV-D380P DVD Player/VCR
Does a Sony D380P play. blue ray. Disc..?
No. DVD cannot play Blue Ray disc.
You need a BluRay player or PS3/4.
The technology and the media capacities are very different.
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 22, 2018 | GE Televison & Video
I own a sony dvd player /vcr combo model no. slv-d380p it plays dvds in black and white instead of color
The problem is in the color processing ic, far cheaper to replace the player than have it repaired.
Mar 10, 2012 | Sony Televison & Video
DVD Player does not recognize disk and displays 'insert disk' message.
Sounds like compatibility issues, your player maybe old enough not beable to recognize newer disc.
Aug 10, 2009 | Sony SLV-D380P DVD Player/VCR
I have 3 vcr's and none of them will play my tapes. (just Static) I have sound and I can play DVD's.
Perhaps some of the belts that help your vcr run are stretched out. These belts can be replaced through your manufacturer or you can get them from your local Radio Shack.
Aug 07, 2009 | Sony SLV-D380P DVD Player/VCR
Region free method for Sony SLV-D380P
I also need to unlock my Sony SLV-D380P
Dec 24, 2007 | iLO DVD Recorder DVDR05
Sony SLV-D380P DVD Player/VCR Logo
147 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
