Computers & Internet Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kingston USB caught a virus that made shortcuts of my files, leaving the originals look dimmed, or sort of transparent. I accidentally deleted the original files.I have used an app called and recovered less than half of my files. Then i came to a point that i formatted my Kingston flash drive. Unfortunately I caught that virus again. What should I do?
Eranda Gunathilaka
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 36 Answers
  • Posted on Oct 19, 2014
Eranda Gunathilaka
Contributor
Level 1:
Cheetah:
Answers
36
Questions
0
Helped
33765
Points
78
Try Shortcut Virus Remover.
It will work against Shortcut Virus.
You can download Shortcut Virus Remover from this link for free,
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
644
Points
First thing update your anti virus program and then for your data from Kingston USB drive, go for Kernel for FAT and NTFS, restore data software which efficiently and instantly recover all type of data from usb drives as well as from the partitions of hard drive. If you wanna try then check the demo version of the software in which you can preview the files like pics, music files etc and then recover all of them by selecting.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Mar 03, 2011
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689237
Points
8444
Make sure you have AV installed.
3answers
Files turned into a folder name shortcut
The file shortcut is a pointer to where the file is located. When you click on the shortcut the computer will go to where the file is located and then open that file.
2answers
Dently deleted pre loaded files on my memorex 2GB travel drive what can i do
you could download and install an undelete program there are many of these which are totally free to use once you have finished just uninstall it or you could just leave it on your hard drive
http://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital cameraclip_image001.gifmemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
here is another yould use if you have no luck with the first
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
3helpful
2answers
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
1helpful
5answers
ALL folder turned into shortcuts and i really don't know how to get back my stuff. You know the hard drive has music shortcut document shortcut. Somebody help me.
You must have had them all selected and then dragged them somewhere, then maybe dragged back, creating shortcuts at that location. This could be done accidentally by holding the ALT key (or if that key is stuck down) while dragging them back or by holding the right mouse button instead of the left. If it was the right-button thing though, you would have had to also left-click on 'Create Shortcut' on the menu that popped up.
If this is what happened your 'real' folders will be wherever you dragged TO and the shortcuts will be wherever you dragged BACK to.
The fact that there are shortcuts is not alarming. Your originals must be somewhere! Use the Search function to search for any file or folder name you can remember. Start at the root of the system (My Computer) to search everything; it could take a while so be patient. When you find the missing folders just select them all and drag back to where they belong (or Cut from current location, Paste in new location).
3helpful
2answers
MY TRANSCEND HARD DRIVE HAS BEEN INFECTED BY A VIRUS WHICH HAS CREATED THE SHORTCUT OF EVERY FOLDER IN IT. MY HARD DRIVE CAPACITY IS 500 GB AND IS EXTERNAL
Is this the Problem???
Only Shortcuts,,,,,,
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
100% free
Setup file to download 1.1 Mb
Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
download link in home page - http://shortcutvirusremover.blogspot.com
164helpful
8answers
Removal of shortcut virus in pen drive
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
DOWNLOAD !!!
I deleted a file from my USB stick and now cannot relocate it as it was the wrong file. Where can I find the file to restore it? It is not in the recycle bin?
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jaz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives , Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Download and install from here: http://www.filehippo.com/download_recuva/
31helpful
5answers
32Gb kingston pendrive not working. Any data copied get corrupted
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
2answers
I cannot format my pen drive due to virus
Make sure you're drive isn't protected or has some sort of file delete block on it.
Grand Canyon Tech
Grand Canyon Tech
