Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
Won;t boot the motherboard asus k8v-vm. boot couple seconds and failed.I turn off the source and after turn on imediatle push the button , try de start but again stopped.can i fixed?or buy another PC?
Posted by Lupascu Laurentiu on
Diether Masing
  • 784 Answers
Check manual ther is option like bios resetor motherboard reset.
Posted on Mar 03, 2011
I can't find a driver from motherboard ..please help me...asus K8V-VM .PLEASE HELP ME
Go to this link and choose your OS then download the drivers.
http://support.asus.com/download/download.aspx?modelname=K8V-VM&SLanguage=en-us
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | ASUS K8V-VM Motherboard
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3 (wish to enhance to windows 7). I tried to install Galaxy 8400GS graphic card but when I start the system with the card, the...
You need the latest display driver for your graphics card.
Click here to download the drivers off the Nvidia website.
Enter the information in the fields as shown below;
Product Type: Geforce
Product Series: Geforce 8 Series
Product: 8400GS
Operating System: Select the operating system you are using. XP or 7 whichever it is.
Language: Choose your Language, English
Then click search and download and install the driver.
This should solve your problem!
Do do recommend sticking with XP as your current computer system will find it difficult to run Windows 7.
All the Best!
damnor01
Jan 19, 2011 | ASUS K8V-VM Motherboard
I have an ASUS K8V-VM motherboard. I recently upgraded the memory to 2GB of DDR400 (2 1GB sticks) It ran fine for the first 3 or 4 days then started having problems booting. After changing the memory back...
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Oct 24, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
My K8V-VM SE MOTHER BOARD .swith on the computer ,K8VVMSE.ROM FAIL INSERT THE FLOPPY OR CD.REPET THIS MESSAGE SURESH
iat the time of boot a message as follows is displayed
"boot block compatible version .005"
bad bios cheksum. starting bios recovery
checking for floppy. floppy not found
checking for cd rom. cd rom not found"
.. using asus motherboard
Sep 06, 2010 | ASUS A8V-VM Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Motherboard drivers
go here: http://support.asus.com/download/download.aspx?SLanguage=en-us
in the upper left corner in input model to search type k8v-vm, under category click all then click search info.
Click on k8v-vm, select your operating system and download drivers
Aug 19, 2009 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Asus k8v-vm motherboard rebooting problem
this is your bios battery put new one in and it should work
Nov 18, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
