Activision X-Men Legends II: Rise Of Apocalypse for GameCube Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Warning "library install.res.1028.dll could not warning
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6808
Points
Minimize the game, even if it freezes, and click cancel on the error box\s that say they can't load whatever file. It will more then likely work then for whatever reason. It's what I do on Windows 7 64 bit to make it work.
Albert
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Mar 03, 2011
 Albert
Expert
Level 2:
New Friend:
Answers
161
Questions
0
Helped
26391
Points
437
You need to delete your saved game data it got corrupted.
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: warning "library install.res.1028.dll could not
This is what I do on Windows 7 64 bit to make it work.: Minimize the game, even if it freezes, and click cancel on the error box\s that say they can't load whatever file. It will more then likely work then for whatever reason.
1helpful
I got problem on SoundMAX.dll error
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
tip
Unregistering DLLs
<p><b>Introduction:</b><br /> <p><b>What are DLL files?</b><br /> <p>DLLs are dynamically linked library files. DLL file contains a list of certain functions that can be used by various applications. Spool32.dll is a great example of how the things work: that file is used by various programs for print control within Windows 95 and Windows 98.<br /> <p><b>Why is it important to unregister malicious DLLs?</b><br /> <p>DLLs may contain information essential for a computer to function properly. Malicious programs may corrupt regular DLL files or they may install new DLLs instead of normal ones.<br /> <p>Deleting DLLs is a risky deal since it can affect computers performance and functionality of many applications. If a malicious DLL is somehow used by a regular application and the DLL file is removed, the application won't work normally even if the deleted DLL is not needed for a program to function. This is why you have to unregister DLLs before deleting them.<br /> <p><b>How to unregister malicious DLL files?</b><br /> <p><b>a) Open Command Prompt window</b><br />Click the "<b>Start</b>" button and select "<b>Run</b>" option. Type "<b>cmd</b>" into the "<b>Open</b>" field and click the "<b>OK</b>" button.<br /> <p><b>b) Unregister malicious DLL file<br /></b>Type "<b>regsvr32 /u filename.dll</b>" into the Comand Prompt window and click "<b>Enter</b>". "<b>Filename.dll</b>" should be the name of DLL file you want to unregister<br /> <p>
on Mar 15, 2011 • Computers & Internet
Miregsvr.exe - entry point not found
what PC (HP, model and number)
what OS>? XP? we can never guess the OS you run.!
what version of loadrunner, there are so many (from v1 to V15 ??????)
and not all run on
windows 95 to W10.
sorry, impossible that.
the work around, is use the correct software.
for your unstated PC./OS
If XP and is infected, like all are,
then there is no work around, the fix there is to reinstall
the OS, clean. (AND LR and the APP under test)
or (long ago cured by OS upgrades) this...
Google DLL H3LL, that too is a big problem before VISTA.
I have installed battelfield bad company 2 in my computer.when ever i try to play it shows a message ("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll
The msvcrt.dll file is outdated you will need to download the latest updates from Microsoft website direct link is below
http://www.update.microsoft.com/windowsupdate/
1helpful
Library install.res.10.28.dll could not be loaded... Using win 7
1helpful
Installed a new hard drive with windows 7. Hallmark card studio was installed on an external hard drive. I don not have the installation disk, it is in storage in another state. when i click on...
You have to have the original software to reinstall a program. Just tranferring the files does not work. By default windows must complete the setup process through windows installer.
Cant install yahoo messanger . with fatal error " failed to load library d3d9.dll
d3d9.dll is a DirectX9 error, firstly you need to have Service Pack 4, secondly install DirectX 9c:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
You should also go to Microsoft Updates and undertake Critical and non-Critical Updates.
2helpful
2answers
Hi, am using Adobe photoshop cs4 extended. Recently when am opening the photoshop am getting the error message that "adobe photoshop cs4: photoshop.exe-entry point not found". and " the...
Which Operating System is running on your computer? If it's Windows XP, you need to delete a file with the name "dwmapi.dll" in the C: drive's System32 folder under Windows folder. If I am right, the problem might have started after installing Mozilla Firefox. The reason is a wrong driver of Windows Vista installed on Windows XP system.
The process is like this:
Open My Computer, then "C:" drive, and again "Windows", locate "System32" folder and again locate "dwmapi.dll" in the System32 folder and delete the "dwmapi.dll". That should definitely do the trick.
Good luck.
Thanks for using FixYa.
1helpful
What am i suppose 2 do?cant access my yahoo messenger quote:cannot load resource dll .
your yahoo messenger missing Dynamic Link Library "DLL" file
Download again and install yahoo messenger
Top Activision Video Game Consoles & Games Experts
Sean Wright
Sean Wright
MegaByteMe
MegaByteMe
john h
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
