Question about Cisco SRP 500 Series with 10100 Mbp SRP521WK9G1 SRP521WK9G1 Router
Hi when i reset cisco srp521 router, what will be the username & password for admin user. thanks aks
Posted by suraparaj on
Roberta Smith
    Brigadier General:
  • 5,158 Answers
The default username is admin.
The default password is admin.
that's the default passwords. it does depend on the type of reset whether you will still have the old passwords or not. be that as it may i'm also including the user manual for you
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
i do hope this solution helps you
thanks
robert
Posted on Mar 03, 2011
I need password for Cisco Router model E1000. User name is Cisco41070.
This is not a default username for this router. you will need to reset the router to get back into it. There is a reset button to press to get it to its default configuration. Then the default username is blank and the password is admin.
Jul 28, 2017 | Cisco Computers & Internet
What is the default username and password for a Linksys/Cisco Wireless -N Home Router to access web-based setup
Connect to http://192.168.1.1/
The default password is "admin". No username required. If you don't remember the correct password and you don't want to use some brute-force cracking software the only option is to reset the router pressing reset for 30 seconds. After that everything should be back to factory defaults including the default password.
If you need any kind of technical assistance you can contact support cell at here
Jan 21, 2013 | Cisco Linksys Wireless N Home Router...
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
When i put in default username and password says its not authorized
Try admin in user anme and admin in password.
If that doesn't work then try admin in only password, leave the user name blank.
If that doesn't work then try some different passwords that you use often.
If nothing is working then you will need to reset the router.
Once you reset the router, you will lose all the settings on the router and you will need to reconfigure it.
See How to setup Linksys router
Apr 23, 2012 | Cisco Linksys EtherFast Cable/DSL Router...
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I secured my router network. I trying to get to set ups.... what user name and password I use? Admin for user name??
username: admin password: admin if that doesn't work, just reset it.
- reset instructions -
Push in the reset button on the back of the router, just to the left of the power port, for approximately 10-15 seconds, then wait 30 seconds, you will then be back at factory defaults. you then login to the router by typing http://192.168.0.1 into your browser, username: admin password: admin
Sep 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I want to change my id user name & password for WRT120N. But I also can't find the program in my computer. Please assit me. Thanks,
In order to access your WRT120N control panel UNDER FACTORY SETTINGS, you must navigate to http://192.168.1.1 in your web browser.
According to Cisco's support site, the default username for the WRT120N will be NULL (left blank) and the password will be "admin".
Once you reach the control panel, navigate to the 'Administration' section, where you should be able to change your username and password.
NOTE: If this does not work, you may want to look into performing a factory reset of your device.
Jun 07, 2011 | Linksys WRT120N Router
Have forgotten the password to this router, need it to set up a Nook reader
Look under or in back of the router you will find a reset button press it with a paper clip or something similar for 20 seconds, that will take the router back to factory default with no security.
hope this helps have a great evening.
May 29, 2011 | Cisco Linksys Wirelessn Router Black...
Can not login on con 0 port (not text), lost
default username and password for all router are
admin and admin
or
admin and password
try these two combinations
else try link
http://www.cisco.com/en/US/products/ps6187/index.html
Oct 03, 2009 | Cisco 1811 Router
Password
try these combination's:
User password
cisco cisco
admin password
admin admin
admin 1234
Feb 12, 2009 | Zonet Computers & Internet
Cisco SRP 500 Series with 10100 Mbp  SRP521WK9G1 SRP521WK9G1 Router Logo
931 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
