Follow this steps :
Tools Required :
- Nemesis Service Suite (NSS)
- Nokia PC Suite
- Data cable
Regain Your Security Code
Steps:
1. Install Nokia PC Suite
2. Install Nemesis Service Suite (NSS)
3. Connect your phone to your PC with data cable. If the phone prompts, choose default mode or PC Suite mode (DON'T OPEN PC SUITE)
4. Open Nemesis Service suite (NSS)
5. Click scan for new devices button (on top right corner of NSS)
6. Click Phone Info button.
7. Click Scan button.
8. Click Permanent Memory tab.
9. Click Read button.
10. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\.pm
11. Open the .pm file using Notepad.
12. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
13. Like 5=31323334350000000000 (Example)
14. Abandon the red fonts.
15. So, 12345 is your security code. (Example)
Now, here is how to reset your security code.
Reset Security Code
Steps:
8. Under Power Mode, click Local and then click Change button. At this part, your phone should restart, and you should see the text Local mode across your phone screen.
9. Under Production Data Edit, click Read button. The textboxes should now contain values.
10. Check the Enable check box beside Product Code.
11. Click Write button.
12. SelectTools button on top
13. Click Factory Settings tab
13. Tick Full Factory button and click Reset button.
14. Final step, go back to Phone Info and click Normal then Change.
Now your security code should be 12345.
There is no (5=) record, please help me out...
[email protected]
