Theater Research TR-9500 Car Subwoofer Box Car Speaker Logo
Posted on Mar 03, 2011
What do they cost new 2 ten inch 4ohm 600w theater research tr9500 series subs in the box
1 Related Answer
Anonymous
  • 124 Answers
  • Posted on Aug 13, 2009
SOURCE: will my amp be able to power the subs? i have a
if ur amp is not 2 ohm stable and ur sub is wired in 2 ohm ur amp will fry.go to crutchfield.com type in wiring subwoofers u can get ideas there
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 • Music
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
1helpful
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
1helpful
3answers
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
1helpful
2answers
Whats is the perfect amp?
I have 2 of these 12" running in a Large slot ported box with an:
"Ultra Linear UL2402"
600RMS X 2 @ 4Ohm (Stereo) 1200RMS X 2 @ 2Ohm (Stereo) 2400RMS X 1 @ 2Ohm (Mono)
Can be run in Tri-mode with 3 8Ohm subs, which these subs are. I have not tried this mode. This is
600RMS X 2 @ 4Ohm = Max RMS of your subs. You should run the max of your subs, less wear on the amp you are using , and i doubt you will ever need to turn it up far before it blows out your trunk or window :P
1200RMS X 2 @ 2Ohm = Blown Subs!
Has 4 x 25amp fuses, most will tell you this only has an RMS of around 845, an "ultra linear circuit" produces twice the output power over Modern amps.
Can had on Ebay for around $100. I bought mine for $101.
This Amp pounds, i could quickly tell a difference going from 300RMS X 2 @ 4Ohm with a Kenwood amp. I Had to turn all my settings down on the new amp to have a better balance in sound.
Top Theater Research Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Theater Research Car Audio and Video Expert? Answer questions, earn points and help others
