Televison & Video Logo
Anonymous Posted on Mar 03, 2011
Hello Can you tell me what I need to repair the STK392-110 Convergence ICs on a Panasonic HD 56". I also need Qty 6 - 2.2 Ohm, 2 Watt, Metal Film Resistors. Is there a good, decent online Electronics Supply Store w/ decent shipping, quality components that you recommend? I am a Certified Electronics Tech, PC Tech & IT Tech looking for a decent Online Supplier. My Email is [email protected] Website - www.appalachia-line.com Thanks in Advance, Paul Rosenquest Appalachia-Line & Solo Star Computers
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Mar 03, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541778
Points
28391
If you are in the UK try www.cpc.co.uk I think they export as well if you aren't.
Hope that is usefull.
2answers
Can you tell me where the 2 Convergence IC's and the 12, 6.8 ohm 1 watt resistors are located in the Magnovox 51MP329H TV
When you remove the rear cover you will see the large green board on the left side. Note the two large aluminum heatsinks with the fins? The 2 Convergence Ics STK392-120 are attached to that heat sink the 12 6.8 ohm resistors are at board location 3149-3160 they are all the 6.8 ohm 1watt metal film resistor located near the Heat sink which has the two ICs.
1helpful
3answers
Pt 56tw53 picture trouble
Based upon your description, the problem area is the convergence circuit. These sets usually have a couple of large black ICs that control the convergence. These Ics either have bad connections on the pins or are failing. You can try resoldering the pins of these ICs if you can solder, or replace them. These ICs are usually marked STKxxx and are attached to a heatsink.
If you get this repaired, expect to pay about $30-$40 for each IC (there can be 2) along with the local labor rate for projection sets.
Dan
1helpful
Panasonic pt-61hx42, turned on tv and the power light blinks three times in a continus pattern. I assume this is a power supply problem, can you tell me which componet is blown?
The three blink error code is the error for failed convergence ICs and the low ohm resiustors. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the 2 ICs and the 6 low ohm resistors plus the kit contains the CD with detailed repair instructions.
Convergence Problem
Replace the Convergence Ics and the six 2.2 ohm resistors. Heres a link to the proper repair kit for your model which contains both Ics and the resistors plus step by step instructions with pics on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Double Display on screen
The convergence Ics need replacement along with the 2.2 ohm 2 watt resistors. There is a repair kit available for your model which contains both the ICs and all six of the resistors and contains step by step instructions with pictures. Heres the link to the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
4helpful
Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
2answers
Toshiba TP43H95
Needed two convergence circuits., three Hi-Temp. capacitor-filters and one 1.8 OHM-2W Power Resistor. ($550.00 parts and labor)
2helpful
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
The magic focus is off on my 53udx10b....how do i fix it and if i need parts were could i get them from?
You will need to replace bothe STK392-110 Convergence ICs and the six resistors . You will need two 3.3 ohm 1 watt metal film resistors for RK42 and RK50, then two 1.8 ohm 1 watt metal films for RK46 & RK54, then one 3.9 ohm 1watt metal film for RK58 and finally one 2.2 ohm 1watt metal film for RK62. You can get the two replacemnet ICs and the resistors at the following link and they will include fre instalation instructions with pictures so you can do the repair your self.
Here is the link.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
