Question about Cisco 7910 IP Phone
How to unlock cisco ip phone 7910 - Cisco 7910 IP Phone
Posted by patnaik1010 on
Anonymous
    New Friend:
  • 125 Answers
  1. Press **# in order to unlock Network Configuration on the phone.
  2. Press Settings.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) for Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
Posted on Mar 03, 2011
2 Related Answers
Anonymous
  • 17 Answers
SOURCE: How can I clear /
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Posted on Jan 11, 2011
Anonymous
SOURCE: 7910 IP Phone
you stupid ****! it needs a voice vlan
Posted on Jan 13, 2010
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
How can I clear / reset a Cisco IP Phone 7910
Oct 28, 2010 | Cisco 7910 IP Phone
I am trying to unlock my phone to program it under sip
Complete these steps:
1.On the Cisco IP Phone, press the Settings button.
2.Press **#
3.When the window displays Settings Unlocked, click the More softkey.
4.You now see the Erase softkey, which can be used in order to erase the configuration on the Cisco IP Phone.
I hope that this has been very helpful for you
If this solution will not helpfull for you that time pls send me a IP Phone details.
Jan 01, 2010 | Cisco 7940 IP Phone
How to Install LIP 7016D - IP Phone,I dont know which IP addresses should I give.
For startimg IP Phone you should have a Router details e.g. TFTP, Gateway (Router IP), if DHCP is configured on your router that time that time pls don't assign mannualy IP on IP phone.
2.Press **#
Dec 23, 2009 | Computers & Internet
How can I unlock a SPA922 that has ben Locked? I can´t do factory resett becouse it is locked!
2.Press **#
Dec 18, 2009 | Linksys SPA922-EU IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
7910 IP Phone
please check if firewall is ON on your netgear router...
Dec 12, 2007 | Cisco 7910 IP Phone
Cisco ip phoe
Is the phones registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes. http://cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a03ptcss.html#wp1020642
If it is CME, then it could be a configuration issue
http://cisco.com/en/US/docs/voice_ip_comm/cucme/roadmap/itsph.htm
Nov 10, 2007 | Cisco 7910 IP Phone
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Cisco 7910 IP Phone Logo
1,388 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Resolution IT Dubai
Resolution IT Dubai
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
