GE 97985 Mouse Logo
Question about GE 97985 Mouse
Left click button wont work
Posted by dgudell on
Marcell Molnar
    New Friend:
  • 48 Answers
Hi, it is either a:
1., software problem (check control panel => mouse for options)
2., hardware issue, listen to the sound of it clicking, if it sounds different from (for eg. weaker) than the right click than it is a faulty switch
You may try taking apart and replacing the switch if you another mouse lying around.
But if are not experienced with soldering, just remap the left click in control panel (replace left click with right click and right click with middle button) or get a cutom mouse utility to do the same.
This way you can use it while you get a new one.
Posted on Mar 03, 2011
Once in a while my Logitech TrackMan Mouse won't left click
usually this is a sign of the button getting clogged or worn down from use. Best bet would be to get a new mouse, gaming mice have very high quality buttons ;)
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
1helpful
2answers
RAT3 Button wont click
i have the same problem now. It started with side forward button first, than my scroll button died and now LEFT is kinda halfway stuck :(
My mouse pad on my lap top isnt working, it moves around but when i click it wont select or click or i dunno what to call it lol, **** the right click works, just not the left.
Sounds like the track pad button is broken. Unfortunately that would mean it needs physically replaced. I might suggest using a USB mouse instead.
1helpful
Two buttons beneath touchpad are not working
You should clean the button by opening the cover, realign it, and check if the button touches to the board.
Speakers wont work without installation cd
Left click on the start button and right click on My Computer.
Left click on Properties.
Left click on the Hardware tab and select Device Manager
You should have at least one device that says unknown..
If so, you will need to locate and install the correct sound drivers.
If the sound card came with your PC and it is a name brand like IBM or Dell, you should be able to find the drivers on their web site.
My zen was working know its not at all wont turn on or off
Just look at the left side of the mp3, not where all the buttons are, but on the bottom left corner of the side of your mp3, and a little tiny barely noticeable button is there. it says "reset" click it and it should reboot or it'll start working
I recently found this out today :)
I had the same problem about like 15 times xD
So hope this helps!
Vaio Sony wont go to the users acount
Hold button down for 5 seconds to switch off. The switch on and press F8 and choose safe mode boot. If it boots try a repair option or system restore to a previous working state
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
2answers
Mouse
Try this, If you have an external mouse port, attach another mouse, reboot laptop. If mouse works, depends on operating system? Goto control panel, mouse icon and see if you might have diabled or changed mouse key to use the right key?
Top GE Computers & Internet Experts
Mike
Marvin
Marvin
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
