An expert that gotĀ 5 achievements.
An expert whose answer gotĀ voted for 100 times.
Sniper:
Expert
Re: I need the original installation cd software that...
Here is the cd software. Here for all the available files for the mobiblu cube dah-1500i from the manufacturer. Use google translate to understand what they mean.
Downloader the firmware updater from the mobiblu site
Install the software, connect the player via the USB cable, set the switch to hold and run the updater. When it is finished, stop the device and disconnect it. When you power up, it will be back to factory settings (any data/music will be erased).
Reload the firmware. The firmware gets a hiccup after repeating songs/switching through songs quickly. Make sure you take your mp3s off before you reload the firmware for the songs will be deleted.
I had something similar with my Cube. WinXP pro would detect it a an unknown USB device. Sometimes when I would manipulate the USB cable, it would detect correctly.
To make a long story short, it turned out the be the USB cable. When I tried a different one, everything worked correctly. Hope this helps.
FYI, my mobiBLU DAH-1500i 1GB unit wouldn't boot. It would start up the musical note logo and stay there. I had to hard-boot it with the little reset button. Then I connected the USB cable and "unloaded" all files, then used Windows to FORMAT the drive (FAT32). After that it fired right up and works fine. I might try to update or reinstall the firmware if it doesn't keep working. Good luck.
