Posted on Mar 03, 2011
7 pints equals what in metric three quarters of a pint equals what in metric half an ounce equals what in metric one and a half pounds equals what in metric 2 pints equals what in metric
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Mar 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
3175
Points
52
Metric what, Liters, milliliters?
1 1/2 pounds converted to what grams, kilograms?
Your answers whatever the values are can be found from any of hundreds of online converters.
You pick the value that you want converted and the value you want it converted to.
One that will work is:
http://www.onlineconversion.com/volume.htm
Good luck, thanks for using FixYa.
2answers
What equals 48 ounces??
Hi Yesenia
There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
Cheers!
tip
2007 Jeep Grand Cherokee Fluid capacities
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION SPECIFICATION FUEL TANK
All Models
76L (20 U.S. Gallons)*
ENGINE OIL
3.0L Diesel with Filter (10.0 Quarts)
3.7L with Filter (5.0 Quarts)
4.7L with Filter (6.0 Quarts)
5.7L with Filter (7.0 Quarts)
6.1L with Filter (7.0 Quarts)
COOLING SYSTEM
3.0L Diesel
13.2L (14.0 Quarts)
3.7L (9 Quarts)**
4.7L (14.5 Quarts)**
5.7L (14.5 Quarts)**
6.1L (14.8 Quarts)**
A/C REFRIGERANT SYSTEM
All Models
0.68 kg (1.5 Pounds)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 545RFE
2WD 5.2 L (11 Pints)
4WD 6.2 L (13 Pints)
Service Fill - NAG1
5.0L (10.6 Pints)
Overhaul Fill - 545RFE
13.33L (28.0 Pints)
Overhaul Fill - NAG1
7.7L (16.3 Pints)
TRANSFER CASE
NV140 and NV146
0.65L (1.4 Pints)
NV245
1.8L (3.8 Pints)
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
1 pint equals how much fluid ounces
US 1 Pint equals 16 fluid ounces
Imperial 1 Pint equals 20 fluid ounces
How many cups are in a quart?
1 Quart [Fluid, US] = 4 Cups [US]
1 Quart [Dry, US] = 4.65458877 Cups [US]
1 Quart [UK] = 4.54609 Cups [Metric]
I've copied and pasted this info for you hope this helps.
Feb 23, 2015 • Motorcycles
How many quarts equal one pint
a half quart equals one pint a quart is 32 ounces and a pint is 16 ounces
How many grams are in 1/2 cup of cottage cheese?
Depends on which "cup" you are using; there are 28 grams per ounce and the dietary cup is a pint, or one pound; so a half pint is 8 ounces x 28 = 224 grams
3answers
1 liter equals how many oz
1 liter is equal to 33.8 fluid ounces.
What equals to one ounce?
What do you mean by "ounce"? There are various units of mass and volume called "ounce."
One English ounce is a sixteenth of an English pound. One troy ounce is a twelfth of a troy pound. A US ounce is a sixteenth of a pint.
k24674
ADMIN Andrew
ADMIN Andrew
