Question about Epson Stylus Photo R300 InkJet Printer
My Epson Stylus photo R300 printer keeps saying CD tray not set properly. I keep reloading it, and it pulls it in like it's going to print, but then spits it back out.
Posted by andreagritto on
Anonymous
    New Friend:
  • 10 Answers
Clean thecd tray especially the tree white marks and load the tray in the printer exactlyto the two marks >
Posted on May 19, 2011
2answers
Linked r300 to pc running windows7.can print photos but not cd's.
Download and install the latest print cd software from here.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R300/Drivers-Support?target=driver&languageId=1&driverId=324514&defaultOSId=3&DRV_CATEGORY_CODE=CREATIVITYSOFT
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Stops printing cd half way
It seems your printer cannot seem to recognize the CD tray. Purchase another CD tray. You can try compassmicro.com.
16helpful
6answers
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
1helpful
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
2answers
Epson Stylus R300 Photo
Clean the white parts on the caddy and also clean the entry/exit rollers (use windowlene and a sponge). If you still have problems see my previous posts about under head cleaning and just complete a quick clean.
This should get you going again.
Epson Stylus Photo R300 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
