Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just got an electro brand mp3 player model #MP2408CP and when i plg headphones or speakers into it, i have to push up on the wire to get sound. How can i fix that?
Anonymous
Level 2:
Sniper:
  • Expert 95 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
95
Questions
0
Helped
84290
Points
438
Your wires in your headphones are probably loose/detached. Best solution is to just buy new headphones. If you don't want to buy new headphones, open your headphones up and solder or tape the wire back the metal/wire.
1helpful
I've purchased some IR headphones to link with my Alpine in car DVD player. The sound is only coming through one side of the headphones?
Have you checked that both earphone speakers aactua Work? If they are not expensive ones, you may have bought a did set.
When i play music and plug in headphones i can hear the song through the speaker on the mp3 and through the headphones. Can anyone tell how to fix that?
If the plug isn't completely in then the sound can come out of both.
Can you specify the brand of mp3 player as that may have something to do with it.
Else it must be a software or hardware issue.
I can only get output sound on my headphone jack not from my speaker out put
Depending on the MP3 brand, if it is an I Pod, the speaker output should be eigther way the headphone jack or the same electric charge outlet, if it is not working as electric charge shouldnt eighter with sound, try blowing the harder you can against the speaker out, do it couple of times, that may work, otherwise some one tried unpluged the sound by twisting instead of pulling out
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
2answers
No audio at all
SOUND PORT PROBLEM CHEAK WITH OTHER YEAR PHONE
1helpful
Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
Sound is warped
Likely what happened is, in your efforts to get the piece out of there, you loosened a solder point on the headphone jack, and it will need to be resoldered. If you don't feel comfortable doing this yourself, you can send it to a technician who can.
Sound - one speaker broken
I suggest try updating the firmware of the player. Have you tried listening to the FM station to see if it is only the songs that are being affecter? Also try to use another headphone.
2answers
Radio wont work (brand new mp3 player)
some of these mp3 players use the headphone wiring as the antenna...are you pugged in? also try removing the batteries for 30 minutes, and then restarting
 Grubhead
Grubhead
SmartAviator
SmartAviator
