Question about Logitech G25 Wheel And Pedals Set
Not turning left anymore maybe a dead motor? resetting the power and it doing the start up check is failing is their a repair for that
Anonymous
    New Friend:
  • 51 Answers
It sounds like the internal gear design is messed up on the wheel. This will have to be exchanged since its not repairable.
I recommend the G27 :)
Posted on Mar 03, 2011
When I turn my key to start I get nothing. No lights, radio, interior lights, nothing
sounds like you need a battery check first, if ok possibly bad connections on battery terminals, possibly duff starter motor or solenoid, failing all that a dead short somewhere maybe need an auto electrician to check it out.
1helpful
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
2010 gmc seirra hybrid 6.0 won't start but all lites and everything works fine. But there's a constant clicking up by fuse box under hood
constant clicking means the solenoid for your starter motor is either:
- Defective (not likely- since the click means it was working momentarily)
- Not getting enough power to stay on (battery is good for light, not for amperage of starter motor)
- Turns itself off due to overload amperage (seized starter motor/engine)
The clicking is commonly just an indicator of a dead battery; the solenoid clicks- connects power to the huge drain of the starter motor- then, as the amperage draw "browns out" the battery, not enough power is left to keep the solenoid on- clicks off. power drain is gone- solenoid clicks back on- (repeat until battery is REALLY too dead to even get the solenoid to click)
Its important to note that interior lights, dashboards, and stereos draw very little power, an are not good indicators of battery charge.
I would recommend getting a jump-start from somebody, before doing anything more intense. After engine is running, maybe bring it to a mechanic to check its battery charging circuit.
Won't start, can turn the knob, all clicking good, no sound of motor starting
Did you check if the motor is receiving power? If no power then a switch or something else is responsible for the no electricity to motor. If motor terminals are being energized, is motor humming? If so, then turn off right away - something in mechanism is stuck and not allowing motor to spin up. Locate what is causing the jamup.
If motor still totally dead, then maybe the motor windings have opened and it is no good.
OR maybe the motor is spinning and you do not hear it - maybe the belt is stretched or broken.
2answers
What could be wrong,My pump wont turn on , it makes noise but wont kick on
open it up and see if the impeller will turn freely when it is disconnected from power. Call pool guy or pool store and see if it just needs a solenoid.
Motor won't start
Make sure water is on. Try pushing test and then reset on the built in GFCI on the plug. If it's not a dead motor, when you hit reset, the motor should kick on for a second when you reset it.
No engine cranck, no warning lights
Check solenoid on starter motor.
A quick fix which works on occasion when solenoid hasn't completely failed is to strike the starter motor body with a hammer whilst trying to start.
Check power to solenoid with the key turned to crank position.
No power to solenoid? Check steering lock cluster, relay and fuses.
Do you have a flashing key on the instrument cluster? Change or re-program the ignition key
If you have no warning lights, no power to solenoid then check negative terminal fixing from battery.
If all is well, yet no crank, then replace starter motor and solenoid.
My Canon Pixma MP 830 went dead during printing.It just will not turn on anymore.Already replaced the power supply,but still does not turn on.Any help would be very much apreciated.
I assume you checked the power cord.
If you have changed the internal power supply (the black box in the left real corner), then all that is left is the main logic board.
That repair would be cost-prohibitive on this model.
1helpful
Whirlpool duet dryer does not run
You did not say if the motor is running, I have to assume that it is not.
You can try this...
Turn off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Then turn your power back on and push the start button.
Sometimes motors will get a dead zone in them and this will move it from the dead zone.
If that doesn't help then you need to check a little farther into why it is not working.
Could be a faulty motor, faulty start switch, broken belt, or maybe a faulty timer switch.
I hope this helps
Kenmore dryer will not start
Check and make sure you have electric going to the dryer.
If you do then listen closely to make sure the motor is not running, sometimes the belt will break and the motor is almost silent when running.
If the motor is not running, it could be your start switch,timer switch or maybe your motor is faulty.
Another thing you can try is make sure your power is off to the dryer, reach inside the drum and turn the drum 1/4-1/2 turn. Then turn your power back on and see if it works then. Motors will sometimes get dead zones in them and this will rotate it out of the dead zone.
I hope this helps
Logitech G25 Wheel And Pedals Set Logo
Top Logitech Video Game Consoles & Games Experts
Ekse
Pierre Laplante
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
