Question about Ovens
Bottom oven element stays hot will not cut off
Posted by ccoxendine on
Anonymous
    New Friend:
    Problem Solver:
  • 17 Answers
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Posted on Mar 03, 2011
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
robert samples
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
Anonymous
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    goober123
    • 9 Answers
    SOURCE: Thermador SC301T heating elements not working (top
    Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
    Posted on Dec 11, 2009
    barkencoa
    Barry Coates
    • 3463 Answers
    SOURCE: Zanussi ZDQ 595 fan oven not heating
    You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
    Posted on May 14, 2010
    Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
    Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
    The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
    Oct 16, 2017 | Bosch Ovens
    Why when i changed the oven bottom element now it seem to stay red all the time and gets very hot beeping sound and f1 on display
    What's ur oven? Ur oven has a heater relay.. K4/k5 relay controlling the heater. It's a small square shape.. Try to trace back the wire..
    Jun 08, 2016 | Ovens
    We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
    If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
    Apr 02, 2016 | Ovens
    Bottom element in oven stays hot all the time. Top element is cool. Only way to turn it off is unplug it
    They are generally located on the control board. In rare cases there is a control board and a relay board. this is usually in some higher end stoves. You could go to sears parts and enter your model number and look to see if there is a separate relay board.
    Mar 11, 2014 | Ovens
    Oven not getting hot
    I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
    Jan 13, 2012 | Frigidaire Ovens
    Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
    Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Apr 17, 2010 | Ovens
    Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
    Jul 09, 2009 | Thermador SC302T Electric Double Oven
    Oven heating element stays on
    If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
    Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
    Ovens Logo
    231 people viewed this question
    Top Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    john h
    Are you an Oven Expert? Answer questions, earn points and help others
