Question about Nortel Lands Phones
I have a Aastra Telecom 9316CW Corded Phone and I have lost my manual. I need to know how to turn the light back on in the window. Please, please let me know or tell me how I can find out. Thank you. Judi
Posted by Judith B Hackett on
  • Nortel Master
  • 6,195 Answers
Do you mean the feature light or the backlight for the display? The feature light can be set to on or off.
To set the light, press Save then 1 (for light on) or zero (light off). Press the desired memory key to associate with the feature and then enter the code from your telephone provider for that feature. Press Save and then label the memory key.
To use the feature light, press the memory key (as selected above) and then lift the handset. Press either Handsfree or Mute. The feature and the light will turn on or off. When the phone is not in use, then Feature On will be seen in the display.
The backlight is not adjustable. You can adjust the contrast with the Contrast button. Backlights do fail over time (but it's not a repair I recommend if the phone is out of warranty).
The manual is available here: http://www.aastratelecom.com/cps/rde/xchg/en-ca/hs.xsl/21564.htm . Look at the bottom of the center section for the PDF.
I hope this helps.
Posted on Mar 03, 2011
I need to know how to setup speed dial on my aastra vista 390
Google Astra phone manuals. Then you can look it up. Hope that helps
Oct 24, 2012 | Aastra Telecom Powertouch/Vista 390 Corded...
Aastra 5631i passcode
you can read your instr. manual or download from www. retrevo.com
or call the supply from the phone or where did you buy the phone and get help via ONLINE via chat or phone.
God bless you
Jul 31, 2012 | Aastra Telecom Aastra 9316 CW Corded Phone
How to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Feb 28, 2011 | Aastra Telecom Aastra 8314 Corded Phone
How do I call forward this phone to my cell?
Forwarding is through the plan provider and part of the voice mail system.
Feb 08, 2010 | Aastra Telecom Aastra 9316 CW Corded Phone
I need to view a user manual. your web site will not provide one
If you are talking about the Aastra 9116, it looks like you can download the user manual at http://www.florenceinc.com/en/new-phone-AASTRA-9116.php (acrobat file)
May 28, 2009 | Aastra Telecom 9116 Corded Phone
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
May 04, 2009 | Aastra Telecom Aastra 9316 CW Corded Phone
Different language
Here is english manual www.aastratelecom.com/cps/rde/xbcr/SID-3D8CCB6A-18527B12/03/9116_ma_en_0304.pdf page 10. talks about changing languages.
Dec 09, 2008 | Aastra Telecom 9116 Corded Phone
Aastra telecom 9316 cw
Yes:
http://www.aastratelecom.com/cps/rde/xchg/SID-3D8CCB73-12A0DEC9/03/hs.xsl/21564.htm#dl_instructions
Look at the bottom of page.
Mar 21, 2008 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Feb 18, 2008 | Aastra Telecom Aastra 9110 Single Line...
Lands Phones Logo
242 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
