Sony SAL-18250 Lens Logo
A
Anonymous Posted on Mar 02, 2011
I need the outer glass for my sal18250, the lens fell of my camera and chipped the glass on the outside, the lens still takes pictures fine it just depends on the way concert lighting hits the lens.
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Mar 04, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
959181
Points
10121
Sorry, but it's absolutely not a DIY fix. Your lens must be professionally repaired and it will not be cheap.
Get an repair estimate and then decide whether to live with the fault or repair/replace the lens.
Camera lens is chipped on the outside edge
If you can get the lens fixed or replaced under warranty, you should do that while you can. Otherwise, a small chip should not impact the quality of pictures you get so long as it's on the edge. I've seen many inexpensive lenses that had many chips around the edge and still took decent pictures.
Faided picture
If you went from inside to outside and immediately started taking pictures, you may have had condensation on the lens and that will degrade your images. Once the camera cools off, the images should come out fine. One other possibility is lens flare that's caused by having teh sun directly hit your lens when shooting. Hopefully this helps!
My d5000 fell on the floor and the filter glass of the lens broke. i tried taking pictures to see if it's still working but the view from the viewfinder is darker than usual and it would not take pics even...
The filter should have nothing to do with the images recorded on camera (I assume it's an UV- or skylight filter).
I'd say there's some more serious damage to your camera and you should take it to an authorized dealer repair shop.
76helpful
5answers
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
2answers
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Cracked lens on Samsung Pro 815
As it would mean the replacement of the entire lens assembly, even if repair is possible it would not be financially viable.
Nikon coolpix p1 camera takes weird outdoor pics
If the playback of old pictures are fine but camera mode displays lines across, you may have a defective CCD chip. These are expensive repair averaging around $110. Some local shop may able to repair it. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
My sony digital camera fell and the pictures are distorted
your lens is off by a gear or two, you need to have the lens repaired. see my solution for the W55 if you can DIY.
Camera fell off TV tray; lens bent and won't retract
i had the same problem. just force the lens back into place. I did that and it worked perfectly!
1helpful
Broken glass on the lens
Are you kidding? A camera lens are a group of various lenses inside. I don't think it's repairable, but I'd say take it to a local photography store and you can get free advice. I think I understood you, but anyone would have to see the damage in person. From here, I'd say you are in bad luck...it's a goner. Also cameras are not designed to take a big fall like that. There is probably more damage than just the lenses.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
