Proview HV-177 17 in. HD-Ready LCD Television Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv on ntsc i want pal option - Proview HV-177 17 in. HD-Ready LCD Television
Shajan RS
Level 3:
  • Master 890 Answers
  • Posted on Mar 02, 2011
Shajan RS
Master
Level 3:
Answers
890
Questions
Helped
286346
Points
2593
If you wish to see PAL color system in the NTSC TV, you can purchase a PAL to NTSC converter from your nearest Electronics Shop.
It will not cost much..
Please let me know if you require any further assistance with this. Thanks for understanding.
On a Craig DVD player how do you change the NTSC to PAL?
NTSC and PAL are not interchangeable on most devices (unless your Craig DVD player is a less common brand that allows this option). NTSC and PAL are the broadcasting standards between different countries. Most of Europe and neighboring areas use PAL. North America and Japan, as well as a few other areas, use NTSC.
These should not affect sound; they affect video. Normally, using a PAL device on an NTSC TV will show a black and white picture with a 50hz buzz present in the speakers. Is that the noise issue you're referring to?
Please help
Have you try: NTSC on PAL TV On • NTSC discs will play correctly on PAL-only TVs.
Off Use if your TV is already NTSC-compatible.
Many recent PAL TVs are compatible with NTSC input and so this setting can be switched off. Check the operating
instructions that came with your TV. See also About NTSC on PAL TV on page 124 for related information.
Does Sharp LC-42SB48UT TV support PAL ? if anyone has this TV you can search under the Option Menu to "Select the video signal system compatible with your equipment from the list...
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
Hi - My question is basic - If I have a NTSC DVR can I use an external PAL tuner to enable me to receive and record NTSC and PAL signals?
There should be an output option that you change to NTSC (on your external tuner), Dvr's are pretty "proprietary", and are very sticky about accepting non-proprietary signals. For instance, a sattelite dish dvr, will not accept these inputs, nor will their hard drives re-format or zero out.
How can I convert the Nuvico NVJV 8000 from NTSC toPAL?
I have the DV3-8000; the service menu can be accessed by holding down keys 1 and 3 simultaneously; there is an option to select either NTSC or PAL; my GUESS is select PAL; don't know if there is more to it than that, but this is a start . . .
2answers
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
I bought an HDTV LCD Sanyo from USA got it with me to Lebanon, when I turn the TV on the picture is so clear but it will not work on the satelite or caple, the picture not clear and has no voice. I need to...
There are currently 3 main television standards used throughout the world:
NTSC - National Television Standards Committee. The oldest existing standard, developed in the USA. First used in 1954. Consists of 525 horizontal lines of display and 60 vertical lines. Sometimes irreverently referred to as "Never Twice the Same Color." Only one type exists, known as NTSC M.
Here is a list of TV STANDAREDS I had for a while and can finally share it with someone. GOOD LUCK!!!! TECHMAN
SECAM - Système électronique pour Couleur avec Mémoire. Developed in France. First used in 1967. A 625-line vertical, 50-line horizontal display. Sometimes referred to by wags as "Something Essentially Contrary to the American Method" or SEcond Colour Always Magenta!" Different types use different video bandwidth and audio carrier specs. Types B and D usually used for VHF; types G, H, and K for UHF; types I, N, M, K1 and L for both VHF/UHF. Different types are generally not compatible.
PAL - Phase Alternating Line. Developed by German engineer Walter Bruch and the German electronic corporation Telefunken. Walter Bruch
patented his invention 1963 and the first commercial application of the PAL system was in August 1967. Also a 625/50-line display and variant of NTSC. Proponents call it "Perfection At Last." Due to the cost of the enormous circuit complexity, critics often refer to it as "Pay A Lot". Different types use different video bandwidth and audio carrier specs. Common types are B, G and H; less common types include D, I, K, N and M. The different types are generally not compatible.
Television Standards by Country
COUNTRY SIGNAL TYPE
AFGHANISTAN PAL B, SECAM B
ALBANIA
PAL B/G
ALGERIA
PAL B/G
ANGOLA PAL I
ANTARCTICA NTSC M
ANTIGUA & BARBUDA
NTSC M
ARGENTINA
PAL N
ARMENIA SECAM D/K
ARUBA
NTSC M
AUSTRALIA
PAL B/G
AUSTRIA
PAL B/G
AZERBAIJAN SECAM D/K
AZORES PAL B
BAHAMAS
NTSC M
BAHRAIN
PAL B/G
BANGLADESH
PAL B
BARBADOS
NTSC M
BELARUS SECAM D/K
BELGIUM
PAL B/H
BELGIUM (ARMED FORCES NETWORK) NTSC M
BELIZE
NTSC M
BENIN SECAM K
BERMUDA
NTSC M
BOLIVIA
NTSC M
BOSNIA/HERZEGOVINA
PAL B/H
BOTSWANA SECAM K, PAL I
BRAZIL
PAL M
BRITISH INDIAN OCEAN TERRITORY
(AF DIEGO GARCIA TV - AFRTS) NTSC M
BRUNEI DARUSSALAM
PAL B
BULGARIA
PAL
BURKINA FASO SECAM K
BURUNDI SECAM K
CAMBODIA
PAL B/G, NTSC M
CAMEROON PAL B/G
CANADA
NTSC M
CANARY ISLANDS
PAL B/G
CENTRAL AFRICAN REPUBLIC SECAM K
CHAD SECAM D
CHILE
NTSC M
CHINA (PEOPLE'S REPUBLIC)
PAL D
COLOMBIA
NTSC M
CONGO (PEOPLE'S REPUBLIC) SECAM K
CONGO, DEM. REP. (ZAIRE)
SECAM K
COOK ISLANDS PAL B
COSTA RICA
NTSC M
COTE D'IVOIRE (IVORY COAST) SECAM K/D
CROATIA
PAL B/H
CUBA
NTSC M
CYPRUS
PAL B/G
CZECH REPUBLIC
PAL B/G (cable), PAL D/K (broadcast)
DENMARK
PAL B/G
DIEGO GARCIA NTSC M
DJIBOUTI SECAM K
DOMINICA
NTSC M
DOMINICAN REPUBLIC
NTSC M
EAST TIMOR
PAL B
EASTER ISLAND PAL B
ECUADOR
NTSC M
EGYPT
PAL B/G, SECAM B/G
EL SALVADOR
NTSC M
EQUITORIAL GUINEA SECAM B
ESTONIA PAL B/G
ETHIOPIA PAL B
FALKLAND ISLANDS (LAS MALVINAS) PAL I
FIJI NTSC M
FINLAND
PAL B/G
FRANCE
SECAM L
FRANCE (FRENCH FORCES TV) SECAM G
GABON SECAM K
GALAPAGOS ISLANDS NTSC M
GAMBIA PAL B
GEORGIA SECAM D/K
GERMANY
PAL B/G
GERMANY (ARMED FORCES TV GERMANY) NTSC M
GHANA
PAL B/G
GIBRALTAR
PAL B/G
GREECE
PAL B/G
GREENLAND
PAL B
GRENADA
NTSC M
GUAM
NTSC M
GUADELOUPE SECAM K
GUATEMALA
NTSC M
GUIANA (FRENCH) SECAM K
GUINEA PAL K
GUYANA NTSC M
HAITI
SECAM
HONDURAS
NTSC M
HONG KONG
PAL I
HUNGARY
PAL K/K
ICELAND
PAL B/G
INDIA
PAL B
INDONESIA
PAL B
IRAN
PAL B/G
IRAQ
PAL
IRELAND, REPUBLIC OF
PAL I
ISLE OF MAN
PAL
ISRAEL
PAL B/G
ITALY
PAL B/G
JAMAICA
NTSC M
JAPAN
NTSC M
JOHNSTONE ISLAND NTSC M
JORDAN
PAL B/G
KAZAKHSTAN SECAM D/K
KENYA
PAL B/G
KOREA (NORTH)
SECAM D, PAL D/K
KOREA (SOUTH)
NTSC M
KUWAIT
PAL B/G
KYRGYZ REPUBLIC SECAM D/K
LAOS PAL B
LATVIA PAL B/G, SECAM D/K
LEBANON
PAL B/G
LESOTHO PAL K
LIBERIA
PAL B/H
LIBYA
PAL B/G
LIECHTENSTEIN
PAL B/G
LITHUANIA PAL B/G, SECAM D/K
LUXEMBOURG
PAL B/G, SECAM L
MACAU PAL I
MACEDONIA PAL B/H
MADAGASCAR SECAM K
MADEIRA PAL B
MALAYSIA
PAL B
MALDIVES PAL B
MALI SECAM K
MALTA
PAL B
MARSHALL ISLANDS NTSC M
MARTINIQUE
SECAM K
MAURITANIA SECAM B
MAURITIUS
SECAM B
MAYOTTE SECAM K
MEXICO
NTSC M
MICRONESIA
NTSC M
MIDWAY ISLAND NTSC M
MOLDOVA (MOLDAVIA) SECAM D/K
MONACO
SECAM L, PAL G
MONGOLIA SECAM D
MONTSERRAT NTSC M
MOROCCO
SECAM B
MOZAMBIQUE PAL B
MYANMAR (BURMA)
NTSC M
NAMIBIA PAL I
NEPAL B
NETHERLANDS
PAL B/G
NETHERLANDS (ARMED FORCES NETWORK) NTSC M
NETHERLANDS ANTILLES NTSC M
NEW CALEDONIA SECAM K
NEW ZEALAND
PAL B/G
NICARAGUA
NTSC M
NIGER SECAM K
NIGERIA
PAL B/G
NORFOLK ISLAND PAL B
NORTH MARIANA ISLANDS NTSC M
NORWAY
PAL B/G
OMAN
PAL B/G
PAKISTAN
PAL B
PALAU NTSC M
PANAMA
NTSC M
PAPUA NEW GUINEA PAL B/G
PARAGUAY PAL N
PERU
NTSC M
PHILIPPINES
NTSC M
POLAND
PAL D/K
POLYNESIA (FRENCH) SECAM K
PORTUGAL
PAL B/G
PUERTO RICO
NTSC M
QATAR
PAL B
REUNION SECAM K
ROMANIA
PAL D/G
RUSSIA
SECAM D/K
ST. KITTS & NEVIS
NTSC M
ST. LUCIA
NTSC M
ST. PIERRE ET MIQUELON SECAM K
ST. VINCENT
NTSC M
SAO TOMé E PRINCIPE PAL B/G
SAMOA, AMERICAN
NTSC
SAUDI ARABIA
SECAM B/G, PAL B
SAMOA NTSC M
SENEGAL
SECAM K
SEYCHELLES PAL B/G
SIERRA LEONE
PAL B/G
SINGAPORE
PAL B/G
SLOVAKIA PAL B/G
SLOVENIA PAL B/H
SOMALIA PAL B/G
SOUTH AFRICA
PAL I
SPAIN
PAL B/G
SRI LANKA PAL
SUDAN
PAL B
SURINAME
NTSC M
SWAZILAND PAL B/G
SWEDEN
PAL B/G
SWITZERLAND
PAL B/G
SYRIA SECAM B, PAL G
TAHITI
SECAM
TAIWAN
NTSC
TAJIKISTAN SECAM D/K
TANZANIA
PAL B
THAILAND
PAL B/M
TOGO
SECAM K
TRINIDAD & TOBAGO
NTSC M
TUNISIA
SECAM B/G
TURKEY
PAL B
TURKMENISTAN SECAM D/K
TURKS & CAICOS ISLANDS NTSC M
UGANDA
PAL B/G
UKRAINE
SECAM D/K
URUGUAY PAL N
UNITED ARAB EMIRATES
PAL B/G
UNITED STATES
NTSC M
UNITED KINGDOM
PAL I
UZBEKISTAN SECAM D/K
VENEZUELA
NTSC M
VIETNAM
NTSC M,SECAM D
VIRGIN ISLANDS (US & BRITISH)
NTSC M
WALLIS & FUTUNA SECAM K
YEMEN
PAL B/NTSC M
YUGOSLAVIA PAL B/G
ZAMBIA
PAL B/G
ZIMBABWE
PAL B/G
2answers
Rf signal pal to ntsc
there should be an option in your picture settings menu
1helpful
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
PAL problem
Hi!
The DVD player you have is only compatible with NTSC TV. There is no way of changing that to PAL.
It is compatible though with PAL discs. It will convert the video signal of a PAL disc to NTSC format.
Top Proview Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
