Most likely you switched to much to here and there, it harmed the
plugging but try the it again with the tv and if it works its the
laptop for sure w/b
Try restarting the computer and it should allow you to switch the default device without removing it. make sure in properties its enabled to use the specific device. I can assist more over skype aryon314
You don't remove any drivers (or so) by changing the output. Keep the output at the desired one and in case you use the laptop without the TV change the setting in order to use the internal speakers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
