Question about Saniflo Plumbing
I have a Saniflo which manages waste from a lavatory, a shower, and a sink (all in same room). The saniflo is immediately behind the lavatory, the shower is about 2 m from the saniflow and the sink about 3m. The shower outlet (at feet level) has a head of only about 200mm to inlet of Sanilo. About every 4 years the Saniflo sludges up and I have to remove it and completey clean it out, finding the inlet flapper valves (L and R side of saniflo from shower and sink) are sludged up; there is sludge in the main tank of the Saniflo. Is there a safe product (eg "Drano") I can routinely pass down the shower/sink/lavatory to de-sludge? Is there anything else I can be doing to lessen the need of this my favourite 4-yearly job? Cheers, Giles Wynn-Williams (Dunedin New Zealand)
Posted by giles_wynn_w on
Jack Spooner
    Genius:
  • 1,015 Answers
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
Posted on Mar 02, 2011
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
Water won't drain from sink or shower and the system is whirring away.
there is a blockage in the saniflo pump or the saniflow outlet pipework
Dec 07, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
Can i discharge saniflo into bath waste
These usually have a larger drain line than a shower or bath. If you are draining into a smaller drain then there will be a considerable amount of backing up. This is not a good idea. hope this helps. Good luck.
Jul 31, 2009 | Saniflo Sanibest macerator with multiple...
Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Nov 21, 2008 | Saniflo Sanibest Grinder Pump Only 013
Plumbing Logo
684 people viewed this question
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
