Question about Activision Personal Roots Deluxe Full Version for PC
I have an old program of Personal Roots Deluxe, on a CD, can I download it on my Computer with Windows 7 , any help would be appreciate. Full version, I put the CD in, it would run, but just could not get it to open.
Posted by gwilcox92 on
Richard Dickenshied
You should be able to open the program using DOS Box
Posted on Nov 26, 2011
BobLC
    Sergeant:
  • 239 Answers
I suspect that win 7 doesn't support this software. I am not familiar with win 7 but apparently you can install programs in XP mode which may well help you in this case
Posted on Mar 02, 2011
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
I need a copy of Expert Software Personal Roots Deluxe
For every software that will establishes a good variations to make it a perfect development in achieving a way in exerting much understanding with 3d interior software.
b2b.lovemyhome.net/contact.htm
Oct 22, 2012 | Activision Personal Roots Deluxe Full...
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
Apr 09, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Windows 7 Home Premium will not recognise the extension .ES$ which 'Expert - Personal Roots' applied to an old program which used Windows 95. Can W7 run such a program ?
No - the program is too old. But you can do something else: You can install a Virtual Machine program, like
http://www.microsoft.com/windows/virtual-pc/
in 7, in the virtual machine you can install Win95 , in it you can install the program Expert - Personal Roots and with it open your file and save it in another generic format.
Nov 26, 2010 | Computers & Internet
I have a cd, personal roots deluxe. it says windows95 installation. can i install this on windows vista home premium
If the software was made to support Windows 95 and above, it wont hurt to try and see if Win Vista will accept and run the program properly. The worst thing that can happen is that the installation will not complete.
The software might be too old to run properly on Win Vista, or if it does allow it to install the graphics may seem really old and funny looking - but it won't hurt anything to try and find out.
Nov 08, 2010 | Microsoft Computers & Internet
I would like to install 3D Home Architect 3.0 Deluxe on a computer running Windows 7. I've tried a few fixes I found on-line w/o sucess. Is this possible? If so, how? Many thanks.
1. Change the Settings of the Program:
  • Start
  • Control Panel
  • Programs
  • Run programs made for previous versions of Windows
  • select "Next", "Not Listed", "Next", "Browse" and locate 3DHOMEV3.EXE on your HD.
  • select "Open", "Next", "Try recommended settings", it will pick the recommended settings, select "Next
2. Copy missing dll's:
  • Search for the following files in the 3D Home Architect Installation CD and copy them to C:\Windows\System
  • D3DRM.DLL
  • D3DRM8F.DLL
  • D3DRM16F.DLL
  • D3DRM24F.DLL
  • D3DRM32F.DLL
Hopefully this will help you too! Good luck :)
Sep 12, 2010 | The Learning Company 3D Home Architect...
I tried to install Printshop deluxe 22 on my new computer which has windows 7.it says that there is an error.what would you suggest
I suggest that you tell us EXACTLY what the error-message stated.
Or, start the Windows Program Compability Wizard, and tell Windows 7 that you want to install a Windows XP program.
Then, install the software.
Aug 22, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Would the Broderbund American Greetings Spiritual Expressions 7 be compatible to Windows 7? And does this CD have the same spiritual pictures as the American Greetings Spiritual Exressions that I bought...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Aug 21, 2010 | Broderbund American Greetings Spiritual...
I have been using the Bible Library deluxe for several years but it seems incompatible with my new computer with windows 7. Can I downlowd a version for use with windows 7
Bible Library Deluxe Special Edition Version 5.1 System Requirements
**We can only warrant and support our products when they are run using a computer for which they are designed.
Minimum System Requirements are the *very* minimum specs that your computer needs to run the software. If you try to use the program when your computer does not meet the minimum system requirements, you will experience a wide array of unpredictable results. Operating System: Windows® 95/98/ME/XP
RAM: 16 MB
Hard Drive Space: 3MB Free
This is from their website,sorry but Win 7 is unsupported.
Jan 19, 2010 | ValuSoft The Bible Library Deluxe Special...
How to make programs, like Magix MP3 Maker 12 Deluxe compatible with Windows 7
yes can be, just follow these steps:
Sep 25, 2009 | Magix MP3 Maker 12 Deluxe Full Version for...
Activision Personal Roots Deluxe Full Version for PC Logo
1,318 people viewed this question
Top Activision Computers & Internet Experts
k24674
Your Consultant
Are you an Activision Computer and Internet Expert? Answer questions, earn points and help others
