Question about Marantz PMD222 Handheld Cassette Voice Recorder
Pmd 222 will not record with mic internal or external will play back will record telephone jack will erase is this pre-amp problem
Posted by dalemillar1 on
1 Related Answer
Anonymous
  • 1512 Answers
SOURCE: I have just purchased a
Hi wangkatja
There is little that the user can do to introduce hum to a pro recorder like this, so it will not be something you are doing. Does the unit still do this when you are recording from batteries. If not, this would point to the power supply having poor regulation. If the gear is brand new, I suggest returning it to the supplier and get them to sort it out for you. Marantz service is generally pretty good.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 15, 2008
1helpful
The input levels of the left and right microphones are highly inequal, what can I do?
perhaps the left speaker is damaged
what i would do is load a known mp3 too the sdcard
and play it back on your unit
if its aok level wise
then the left mic has an issue
try an external input too the left mic
if it again records bad there is an issue with the input amp and alc circuit
if it records ok chances are the left electret mic has failed and will need replaced out usually these small mics have an amp built in then this output goes at line level to the input switched between line level in mic in or internal mic in as a mix....
2answers
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
The Mic is not working
right click on the speaker icon and make sure external mic is set up. One time I had to use my internal mic to record stuff it was a pain.
Play back devices
Recording Devices
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
3helpful
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
I am attaching an external microphone and need to mute the internal mic. They both work and it echos. PLease help.
Adding a mike doesn't create echos/feedback. Windows? Version? Right click on speaker icon in lower right and go to recording device mixers, can mute and adjust level of sound sources, also microphone power and pre-amp. Telephones and other devices (laptops) with both input and output will feedback unless the input is "noise cancelling", so you will have to be much more careful with the placement of the external mike compared to using the built in mike.
2answers
Mic stop working
Open Sound devices from Control panel & do the following
1. Click Advanced button in Volume tab
2. Select Properties from Options menu
3. Click Recording & press ok
4. Now select Internal MIC
Hope this solves your problem
2answers
Telephone recording
Yeah, um connect it to a phone in a room that is normally isolated from traffic. Not an ideal solution but as it is a machine and has only an external mic (it doesn't have an internal mic does it?) this is the only solution really, remove all noise except phone conversations.
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Open Questions:
See all Marantz PMD222 Handheld Cassette Voice Recorder Questions
Marantz PMD222 Handheld Cassette Voice Recorder Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
