SOURCE: GMC Jimmy 1998 4X4 4
No, the problem is not yet overcome, but it appears as if this fixer-uper has been fixed up before with steering parts that are not compatible with '98 Jimmy's. I've left it in the hands of a local GM geru who claims to be able to fix it. I'll keep the email and keep you posted.
SOURCE: 1995 GMC 2500 4x4 wont shift into 3rd or overdrive most of the times
i have heard that the ignition switch can be faulty and not let the full voltage thru to the electricaly controlled 4l60e trans.i have the same problem with my 95 1/2 t. i rigged a switched wire from the fuse block via a relay to the proper wire on the trans....ask a trany tech and they will know what im talking about,,,good luck
SOURCE: Speedo stopped working and tranny wont shift out of first!
I will try and clear up any confusion about the different model designations.The trans was first introduced as the Turbo Hydramatic 700 r 4.Later in the evolution of that family,it had improvements made on it by the factory engineers,and they redesignated it the 4L60 model.The 700/4L60 uses a throttle valve cable as a mechanical indication of the throttle position....to the trans.The TV cable regulates mainline hydraulic pressure inside the transmission.This model also uses a governor as a road speed mechanism.It is responsible for the TIMING of the upshifts,and is responsible for the trans being in first (low) gear from a standing start.In 1993,the 4L60E was introduced to the lineup.Same trans as the 700/4L60,but now it is totally electronic,and totally controlled by the PCM (Powertrain Control Module) based on electrical inputs/outputs from the trans,throttle position sensor,road speed,etc.The engineers took the 700/4L60 and did away with the governor and TV cable,made it totally electronic.Early 700's had a mechanically driven speedometer,while the later 4L60's and E's had an electronic speedometer.1993 was a transition year.I have seen both,the 4L60 and the 4L60E in 1993 model trucks,it depends on the month of the manufacture of the vehicle.Your truck could have either,or.The way to visually identify the difference is........on the driver side,the 700/4L60 trans case will have a round,black,governor cover,about 3 or 4 inches in diameter.The 4L60E case does not.The 700/4L60 also has the TV cable mounted on the passenger side of the trans case,and it routes up to the throttle body/gas pedal/accelerator linkage.The 4L60E does not.Recently,the 4L65E and 4L70E versions have been put into production.Based on your description of the malfunction symptoms,i would be inclined to say yours is probably the 4L60E version,because the speedometer malfunction occuring at exactly the same time as the shift malfunction.On a 700/4L60,the speedo malfunction would have no affect on the upshifts,the trans would operate normally.On the 4L60E,a speedo malfunction would likely cause no upshifts.You should still visually verify by the governor cover,or lack thereof,on the side of the trans case.It could just be a speed sensor malfunction if it has the "E" model.If so,it would have set a trouble code which can be accessed with a scan tool or a code reader.Hope this eliminates any confusion.Good luck!!
SOURCE: 1995 GMC Siera Truck Transmission
i gather its an auto transmission ,which mean your loosing oil pressure from the convertor inside the tranny housing.
SOURCE: 1993 GMC 1500 4x4 poor shifting
this may be due to a poor connection at the vehicle speed sensor on the transmission, pull the connector off the sensor and clean it with contact cleaner, if the problem persists replace the speed sensor. there are 2 diff ones here is a picture of the most common one for an auto trans.
