Question about Kenmore Ovens
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read out. I tried holding down the light button and it says loc off, but it's still locked.
  • 7 more comments
  • Anonymous Mar 02, 2011
    I have tried pressing the clear button, several times and unpluged the oven for over an hour and the problem still remains.
    After using the self clean function on my Kenmore Elite electric range, I am getting an F5 code. I have tried resetting by pressing the stop button and the light button, even unplugging the range, but the door is still locked. Bryce
  • Anonymous Mar 03, 2011
    Tried the self clean again, it goes back to E5 after about a minute. What now? How to I unlock the door manually? Bryce
    Where do I insert the screwdriver. I don't want to damage the cabinet.
    I've tried holding the light button. The readout says loc off, but the little locked readout remains and the door is still locked I have held the light button for 2 minutes and still nothing else happens.
    Where is the latch, do I need to lift the cooktop? If so how do I do that?
    I have tried pushing the light button, the stop button, running the self clean again and unpluging the range. What do I do now? They keep telling me to open the door, with a screwdriver, but I can't even see the latch, how do I release it?
    Have turned the power off for over hour. still F5 code. How do I get the door open to check the probe. I have been told about 4 times to open it with a screwdriver. HOW?
  • Anonymous Mar 23, 2014
    two little rectangular lights appear.manual says to hold buttons (-,+)simultaneously, no response
Shane
  • 668 Answers
The error code F5 indicates the electronic control board has failed. The failure could be the sensor probe, loose or bad sensor probe wire harness connection .
This error code can sometimes be caused by a power surge or glitch through the electric lines. You can try shutting off the circuit breaker to the electric range for 2 minutes. If the code returns after powering the oven back up, then you will probably need to replace the control board.
Before replacing the control board, the sensor probe needs to be tested.
Remove the oven temperature sensor probe from inside the oven cavity. It will be protruding into the oven cavity at the upper left hand or upper right hand corner of the rear wall. It will be secured to the rear wall with two (2) screws. Remove the two screws and pull the oven sensor probe outwards and disconnect it from the quickly disconnect plug. The oven sensor probe will need to be tested with an ohm meter by measuring the resistance of the oven sensor. Measure the resistance by placing the meter leads across the two wires of the oven sensor. The resistance should measure 1100 ohms at room temperature (72 degrees).
If the ohm reading is close to the 1100 ohms it should be reconnected and measure where it connects at the Electronic Oven Control (EOC) board. If it measures the same, I recommend replacing the Electronic Oven Control board. If it does not measure at 1100 ohms, replace the oven sensor probe.
Hope this helps.
Shane
Posted on Mar 03, 2011
Daniel Scott
  • 4,323 Answers
Hi
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if the not then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 02, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Mar 03, 2011
    The door latch assembly has gone bad and should be replaced....you can insert a screw driver to open it
  • Daniel Scott
    Press and hold the light switch; the "locking mechanism" resets itself and then the door will open. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
  • Daniel Scott
    OK then insert the screw driver where the latch is and try opening it
Ishola Olayemi
    Genius:
  • 1,196 Answers
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
  • Ishola Olayemi Mar 02, 2011
    The "F5" error on Electric ovens means that the safety circuit
    failed. This could occur because of a power failure or an error with the
    lock circuit. Unplug your oven for 30 seconds and plug it back in. If
    the error remains, replace the lock circuit. On this is done, your problem is fix.
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have the Samsung Electric Induction Range FTQ307NWGX. I had it on self cleaning overnight and experienced a power blip during the night. In the morning found oven totally out with door still locked. ...
Since I have not worked on one nor do I own one take this as a suggestion. According to the manual, you can't use the cooktop when in the self clean mode.
If I were you, I would make sure that the cooktop was shut off and then try to get the self clean to start again. If it will complete the self clean cycle then it will unlock.
BTW you can download the manual from Samsung, that has the troubleshooting guide for free.
Jun 01, 2011 | Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Bottom of kenmore oven pitted
Baked on debris causes this. The spots are from food sitting there without being cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 08, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Elcectric self cleaning Kenmore oven directions needed
It was easier than I thought. I was watching the other postings scroll by and saw the answer, posted months ago, right in front of me. I was missing the last step...pushing the up arrow button.
Jan 29, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Can you over ride a self cleaning oven once it goes on?
you acn CANCEL the cycle, but will lremained locked unitill it cools off!
Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
117 people viewed this question
Top Kenmore Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
