Televison & Video Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Radio Shack 6 in 1 remote (15-1923) and a Sansui RZ-3000 receiver. Had to change the batteries and lost the connection. What code can I use to make this work again?
Level 3:
  • Televison & ... Master 6,687 Answers
  • Posted on Mar 02, 2011
Cindy  Wells
Level 3:
Answers
6687
Questions
0
Helped
3529220
Points
21743
The Sansui receiver should be programmed manually. Turn on the receiver manually, then press and hold Setup until the light turns on. Press the button that you want to control the receiver. The light will blink once. Aim the remote at the receiver and press On until the unit responds. When the device turns off press ENT within 5 seconds. If you miss the code, press repeatedly Last and then On until the receiver responds. Then press ENT. Check if the code works. If it doesn't repeat the code search but wait longer between key presses.
To record the code, press and hold setup until the light turns on. Then press the device control button. Then press 0-9 individually (wait a few seconds between key presses) until you see the light blink. That will be the first digit in the code. Repeat the 0-9 sequence for the second and third digit in the code.
Radio Shack has the code list and manual here: http://support.radioshack.com/support_video/42245.htm . Sansui CD player, TV and VCR codes are listed in the documentation.
I hope this helps.
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
1helpful
Need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
2answers
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
