Intel D101GGC Motherboard Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect audio & usb connection to mother board from front panel model no d 101 ggc help me
Matthew Kubin
Level 2:
Sergeant:
  • Expert 162 Answers
  • Posted on Mar 02, 2011
Matthew Kubin
Expert
Level 2:
Sergeant:
Answers
162
Questions
Helped
28304
Points
570
Do you have the manual? there should be everything you need.
If you don't have the manual, here you go ;) Just follow the instructions and you'll be fine.
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
1576
Points
22
Here is a pdf of the board layout
http://downloadmirror.intel.com/15113/eng/D101GGC_QuickRef03.pdf
Your front USB ports will plug into #9 and the front Audio will plug into #10
1helpful
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
2answers
Dear i have problem in my frent panel cuble... can you tell me where i put these cuble
On the mother board 3 plug in connecters are there
USB 1
USB 2
Front Audio
You can connect the front pannel cable accordingly.
1helpful
2answers
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
11helpful
3answers
Dg 101 ggc drivers
You can download the required drivers by clicking the link below:
Intel DG101GGC Driver Downloads
On the page which opens, select your operating system to download the appropriate drivers.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
1helpful
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
7helpful
Intel D 101 GGC motherboard not getting sound from mic .
It should be having integrated sound(Realtek) audio which may require updating to the latest one released by Intel for the D101 series. Visit their website(Intel) to get the latest drivers and if the mike is in working condition then check whether it is enabled in the audio properties tab...........sodeep
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
2helpful
3answers
Sound driver problem
There you go!
Select "latest drivers"
You will find the drivers you need there.
Good luck
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
