GE 27923GE1 Cordless Phone Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I program numbers into the memory? - GE 27923GE1 Cordless Phone
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • GE Master 102,366 Answers
  • Posted on Aug 19, 2011
GE Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432994
Points
622693
The memory instructions are on the sixth column of the first page of the manual at
http://www.home-electronics.net/ge/pc/IB/27923GE1_IB.pdf
How would I program a number into this phone?
This is the way to program the numbers
  • 1.Lift the handset and press PROG button.
  • 2. Enter a phone number as you would dial it.
  • 3. Press PROG again and then press the corresponding memory button to store this number. Hang up immediately.
  • 4. The number is now stored into memory. The memory button in the lower right corner of the frame can be programmed for emergencies. Whenever the handset is lifted, a light will guide you to that button.
  • Note: Press the REDIAL button to insert a pause in the numbers you are.
Pleas this link, for the phone user manual http://www.startechtel.com/docs/76593.000_Manual.pdf
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 • Cell Phones
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
3helpful
2answers
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. [email protected]
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
19helpful
2answers
Programming numbers
Press the button at the bottom left corner in the one touch dial section.  Dial the number you wish to program.  Press the memory button which you'd like the number stored under.  Repeat as needed.
Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
