SOURCE: Red blinking light over normal wash
I had the same problem... the lock on light was blinking continuously. The solution required disassembling the door to get to the control panel electronic board. You'll notice a flat transparent cable coming out of one end, twisting under the board and going into the door panel. In the middle of the door, there's a number of wires taped together that curled over the flat cable. Look for any black tape residue on the flat cable, which seemed to be causing a short circuit and confusing the electronics. After carefully removing the tape residue from the flat cable, the problem went away.
Hope this helps :)
SOURCE: Model 665.1388 Clean light flashes 6 times and
Hi You can reset the flashing clean light by pressing these
buttons in sequence-high temp wash-heated dry-high temp wash-heated dry. Hope
this helps... Daniel
SOURCE: I have a Kenmore Elite ULTRA WASH Dishwasher
Hi
This issue appears due to stuck keys on control keypad or due to moisture/shorted connections on the keypad. Sometimes this appears when the door is not closed or door lock switch is failing. Turn off the power to dishwasher, unplug the power cable from outlet or shut off the breaker. Use a multimeter and make sure that the connection to door switch assembly are fine, also check the continuity of the door swiches (when closed). If continuity is present you would need to check the connections to the keypad. Try disconnecting the P1 connector(connects keypad to control board) and then reconnecting it, check if the problem is still present. Replace the keypad if the problem still appears. Please check the below pictures, they might help you--
Link 1 (Door Switch)
Link 2 (Keypad)
Hope this helps... Please post back if you need more information.
Daniel
SOURCE: Found cycle not finished, water
Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then it means that the control board has gone bad and
should be replaced. Hope this helps...please post back for further assistance. Daniel
SOURCE: my kenmore ultra wash instaled
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump. Please check the link below: http://www.espares.co.uk/advice/dishwashers/a/3 Thank You for using Fixya
