I had the Fujitsu 93GX scanner hooked up to a Windows 2000 machine and it worked perfectly. The machine recently died. I moved it to another Windows 2000 machine. If I try to run ScanPartner the machine blue screens. However in Adobe if I try to get a document it will only use the bed, I don't know why it will not use the ADF! Please help.
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
Here's what I've done. Maybe it's too late to help.
1) install the latest driver
2) restart
3) go to device manager
4) right-click on unknown device and click update driver
5) Select Let Me choose and select an imaging device
6) Click have disk and browse to c:\windows\fjmini and select fi4120c.
7) let it install the unsigned driver
8) You may have to restart after installing
9) Try opening your scanning software and then select the WIA driver for your scanner
I've installed many fujitsu scanners on windows 7 systems
Works perfectly.
You will probably have to call Fujitsu to advise them of your problem and get the Adobe Acrobat 9 license once again as well as the driver you require. You cannot move this scanner from one computer to another without first deleting it from the first computer. Fujitsu is very helpful and will give you great advice.(I kept forgetting to delete the program before moving it to another machine and they were very helpful when I called to ask what to do.)
Hi ocdaveymac
Fujitsu fi-4120c scanner drivers can be found at driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
You did not mention the model number of your scanner. If you recently upgraded to windows 7 and the scanner worked before than you probably need to update your driver.
here is link you need. select your exact model and OS and download the driver and install it. If this doesn't fix the problem. let me knowhttp://www.fujitsu.ca/products/scansnap/
Yes you can. You need a small scan application whitch allows you to scan multipages. There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
