Question about Sony Cyber-Shot DSC-P73 Digital Camera
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
Muhammad Uzair
    President:
  • 287 Answers
Hello and Welcome to Fixya
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Posted on Mar 02, 2011
Polak potrafi
    New Friend:
I PUT LITTLE PAPER UNDER CARD WHEN INSERTED.!!! THATS THE SOLUTION BECAUSE CARD IS NOT CONNECTING WITH CAMERA! CHECK IF THERES LINE ON EVERY COPPER END OF MEMORY STICK. IF NOT ON SOMME IT MENS NO CONNECTION CAMERA- MEMORY CARD. DONT BEND CARD TOO MUCH . I BROKE MINE THIS WAY. PAPERS SHIMS BEST SOLUTIONS SONY P73 memory stick error 13:01
Posted on Mar 18, 2012
Memory Stick is empty and when I turn on my Sony Syber-Shot DSC-P73 Digital Camera its telling me Memory Stick Error and I don't know why?
that happens due to contact/virus ,so formate the card.Clean the contacts of the card/card reader of the camers,if needs chaque the proper connections .
Apr 16, 2010 | Sony Cyber-Shot DSC-P73 Digital Camera
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
The only functioning modes are the picture viewing & set up modes
Have Sony DSC-P73 with exact problem. Only turns on in SETUP mode and when switches to all other modes camera shuts off usually with lens extended. Have tried new batteries - new memory stick - new everything and nothing helped. I just took out the batteries and attached the AC ADAPTER and all works perfectly now so problem is with either batteries - battery compartment or battery connections. As long as you do not need a "PORTABLE" camera, using AC Adapter solves this problem :)
Dec 25, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory Stick error
Not all camera's accept all card manufactures. There are still compatibility problems. This is no surprise.
Nov 12, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory stick
128MB or 256MB Memory Stick will be fine for DSC-P73
Jul 29, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory stick error
If it says there is a memory card error it means there is a problem with the memory card or the capacity of the memory card is too much for the camera if u have tried using a diffrent memory card and the camera is compatible with it that says that the camera is defective
Feb 17, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Memory Stick Duo Adapter
When you download to the computer, what program do you open with? Try not using the auto-open feature, and open direct from new device in "my computer".
Ed
Dec 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
